Cayenne with 20" but not lowered?
Old Dec 4, 2008 | 10:19 AM
cellg8's Avatar
cellg8 is infamous around these parts
Does anyone have pics of Cayenne on 20" rims without lowering?
How much higher will it be (compared to stock 18's) if I install these 20's without lowering?
My 08 Cayenne S does not have air suspension so I am also wondering what lowering options are out there? What do you recommend?
Thank you in advance.
Old Dec 4, 2008 | 12:05 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
do you have air suspension?
If you do I would only go with the module, and not springs.
If I was to lower mine, I would go with the Techart Probably.
As for a stock picture, I can post you mine.
They are 21's though, and it is not lowered.
Have fun.
Old Dec 4, 2008 | 12:08 PM
cellg8's Avatar
Hi Jace,
Thank you! Your car looks great!
No, i do not have air suspension...
Do you have a side shot of the car? I want to see how much gap there is...thanks!
Old Dec 4, 2008 | 12:26 PM
Jace's Avatar
Originally Posted by cellg8
Hi Jace,
Well unless you have a GTS the gap will be different.
The GTS is lowered a bit from all the other models, plus with that said this car also has air suspension, so I can lower it automatically.
YOu need to get somone with the same model w/o air to take a pic. That would be comparing apples to apples.
Good luck
Old Dec 4, 2008 | 12:47 PM
cellg8's Avatar
i see..thank you!
Old Dec 4, 2008 | 01:12 PM
DEFILER's Avatar
DEFILER is infamous around these parts
CellG8:
I have not done this yet, however, the gap will <appear> to be bigger due to the lower profile tire even though the wheel in itself is bigger. I know you want bigger wheels, but the best thing to do first is spring the $3500 for the KW V3 coilovers which can drop your car 2.5" (adjustable) and also improve the ride considerably. That will improve the appearance considerably even with your stock wheels. It's a lot of money but it's really the only option out there. Springs will only lower 1 to 1.5 inches and in my opinion is not enough to make a difference.
Chris
Old Dec 4, 2008 | 01:31 PM
GMP Performance's Avatar
Site Sponsor
Here are a front and rear shot of a Cayenne without being lowered. This is a 20" RH AU Wheels with 275x40x20 Michelin Diamaris tires.
Old Dec 4, 2008 | 01:49 PM
cellg8's Avatar
thank you for all your help, DE & GMP! Wow..that's a HUGE GAP!
I agree...gotta lower it first!
With KW V3 or any other system, will it cause any negative camber or any other issue?
Old Dec 4, 2008 | 07:48 PM
mungh's Avatar
mungh is infamous around these parts
I also feel like going to KW coilover for my 08 CS.
But I was told install would cost 700.
Then total will be well over 4K, quite high for me.
So I can't decide easily.
JM
Old Dec 4, 2008 | 09:18 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
My CTT has stock Porsche 20s and there's a few inch gap even when in lowered mode.
Old Dec 5, 2008 | 08:03 AM
cellg8's Avatar
Thank you all for all your help.
Old Apr 21, 2009 | 09:16 PM
realmr2001's Avatar
realmr2001 is infamous around these partsrealmr2001 is infamous around these parts
So is your car lowered?
I have KW V3 installed on my car and it rides great...
Old Apr 21, 2009 | 09:30 PM
xXxGhotimanxXx's Avatar
xXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond repute
I've a friend that just bought a Cayenne and is interested in equiping BGF All-Terrain tires and actually using his Cayenne as 4wd SUV/truck. Is there anyone on this board who has outfitted their Cayenne for rugged duty as apposed to sports car duty, and if so...pics. and info. would be appreciated.
J
Old Apr 22, 2009 | 10:42 AM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Check page 2 of my post here. I just went from 18's to 20 and am very happy. No air suspension either.
https://www.6speedonline.com/forums/...ervations.html
dgreen78
Feb 29, 2016 11:28 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
