Check coolant level...
Old Jan 17, 2009 | 02:06 PM
canberk's Avatar
canberk is infamous around these parts
2 days ago, I got the check coolant level message on the dash and topped it up with 10oz water, and the alarm cleared itself. Today, I got the same message again, what do you guys think the reason could be?
Old Jan 17, 2009 | 04:31 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
I am not trying to be a smart-*** but I would guess your coolant level is low. I assume you have checked the level?
A 10 oz top-off is not very much so you could easily still be low. Otherwise, it could be leak somewhere (tank, hose, connection, etc.), loss due to overflow, a faulty sensor, or a number of other things.
If you need much more coolant, you should probably top-off with a Porsche-approved coolant rather than distilled water.
Old Jan 17, 2009 | 10:05 PM
canberk's Avatar
the thing is, engine cooling system works in a closed circuit, so, the water has nowhere to go unless there is a leak somewhere in the system. I'm worried about that... Today, I topped it up with almost a gallon of coolant from Shell...
Old Jan 20, 2009 | 01:43 PM
lsodi's Avatar
lsodi is infamous around these parts
Had the same problem 2009 Turbo S, Dealership had to re-seal housing on top of the engine they said this has happen before. When I get the work order back I will post. Currently car in shop for a new rear axle
Old Jan 20, 2009 | 02:03 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Does Shell offer a coolant that is compatible with Porsche engines??? I thought that was a dealer only item like my Audi and VW was (G12 coolant only)?
David
Old Jan 20, 2009 | 02:36 PM
canberk's Avatar
David
a coolant is a coolant as long as it is liquid, has anti-freeze in it and formulated to not to cause any corrosion, it should be fine. Dealer suggested me to top it up with purified water, but considering the fact that it's 2 degrees outside, I instead put the Shell coolant..
Old Jan 20, 2009 | 02:40 PM
Reborn996's Avatar
That's not what the warning label on my coolant reservoir bottle said on my Audi's!!!
They explicitly said do not mix with non G12 coolant. Not sure if Porsche is the same way.
Old Jan 20, 2009 | 06:43 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Yup.
Old Jan 20, 2009 | 07:38 PM
sparkhill's Avatar
Not even close. That is like saying oil is all the same. Or all gasoline is the same.
Old Jan 20, 2009 | 08:16 PM
canberk's Avatar
oh god, now I have to bring the car into dealer. I'm soo busy this week guys...
Old Jan 25, 2009 | 05:16 PM
canberk's Avatar
brought it in 2 days ago,
got ripped $196 just for flushing the radiator and filling new P-approved coolant...
They checked everything for a leak, pressure tested etc. but they said they couldn't replicate the problem..
The service manager told me that it's normal to lose some amount of coolant over time as it goes out of exhaust (!!???)...
Whatever
Rguy
Apr 12, 2020 11:11 PM
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
XLR82XS
Oct 5, 2015 07:02 AM
TheInfamousDrew
Sep 6, 2015 10:16 AM
faiz
Sep 2, 2015 08:43 PM
