Anyone go REAL off-roading in their Cayenne?
I just picked up an '06 Cayenne Turbo. It came with 22" wheels on 285/35 R22 wheels. I love the look and plan on keeping them, but obviously this setup won't do well off the pavement. I'm probably the very small percentage of Cayenne owners that will be taking their Pepper off-roading and using it to it's true potential. I'm running into problems with finding the right off road wheel and tire combination with some good all-terrain treads. I'm currently looking at the Nitto Terra Grapplers with some aggressive tread. Which setup will fit without rubbing issues?
Stock setup: 275/45 R19 overall diameter: 28.74 inches
Current street: 285/35 R22 overall diameter: 29.85 inches
proposed off-road setup
setup 1: 265/50 R20 overall diameter: 30.43 inches (my preferred choice)
setup 2: 255/60 R18 overall diameter: 30.04 inches
Is anyone running any one of these wheel/tire combos?
Thanks for all your help...although I predict I won't get much responses since it appears the Cayenne isn't really geared toward an off-road crowd like the Range Rovers. Even if there isn't much off-road support for the Pepper I'd still pick it any day over the RR.
not true, they are pretty good off road if you put them on the right tyres + wheels.
Here's a video on it's capabilities. Please do your research before you make any false statements. Thank you for your input.
these things were tested in extreme conditions and were put through some abuse before production. the transyberia models were very reliable and fast. saw it when they actually showed it on t.v. check out their specs, I know they're somewhere on the website, also past excellence mag. this car is very capable of going off road. You ever see BMW racing their X5?
I am not saying the vehicle is not capable. As a matter of fact properly equipped I think it can take on a RR any day. However, Porsche will tell you the vehicle was designed for performance not offroading.
Thanks for all your help...although I predict I won't get much responses since it appears the Cayenne is really geared toward an off-road crowd like the Range Rovers. Even if there isn't much off-road support for the Pepper I'd still pick it any day over the RR.
275-45-19 is what I have on mine, it is an odd ball size. I am not aware of any AT tires for this size. And I would assume it will be even harder to find AT tires for 20" & up that will fit the cayenne. Anyways, for offroading use, 18" is the smallest wheel that will clear the caliper. (17" for the V6 and 19" for the Turbo S)
Also, if you scroll thru the PCM, there is a list of tires you can select. Talk about easy speedometer calibration!
You sure you aren't thinking of the x5?
I run 265/60/18 Blizzaks on 18 inch Porsche wheels in the winter. No problem what so ever. This is on a Touareg btw. But I've driven at loading level and still not rubbing or anything.
Thanks for this info. I will definitely consider this setup.
yeah the cayenne is primarily known for it's excellent off-road capabilities. in 2006, for the first time a cayenne won the Transsyberia Rally, a race from Moscow to Mongolia across some of the roughest terrain on earth. the rally is open to all 4x4 vehicles that are street legal including going up against several range rovers. the following year in 07, the top spots from first to third place were all driving cayenne s'. then the following year in 08, cayennes clinched positions 1-6.
because of cayenne's success in the rally, porsche made the cayenne s transsyberia edition.
i think in the next one.. something like 80% of the teams in the race are going to be driving the cayenne s transsyberia
