need some help
If you are trying to put a widebody kit on of some sort, TechArt has a spacer kit that they use for their magnum which I can get for you. But are you trying to get 86mm total width, or 866 per side (172mm total width)? I am going to assume you need 86 total, or approx 40mm per side????
peter,
should have known to email you first before i post. lol. anyways i need bolts that can fit on H&R spacers. the fronts are 16mm, and the backs are 18mm. i have the rinspeed 22x10. i dont know for sure the offsets on those wheels. if you can do the homework for me and find out what i need, i will get the bolts from you.
thanks Peter,
-chris
thanks Peter,
-chris
