Rear hatch will not open.
Old Sep 6, 2009 | 04:36 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Question Rear hatch will not open.
Any suggestions on how I can get the rear hatch on my CTT to open?
It won't unlock.
Is there a way I can release the hatch manually by pulling a cable somewhere?
Old Sep 7, 2009 | 01:52 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
obviously you have tried both the remote button on your key fob and the button under the rear wiper? failing that if you lift the whole tailgate you can access it through the carpet trim on the back of the tailgate.
good luck
Old Sep 8, 2009 | 01:09 PM
Jeff SD's Avatar
I guess I got lucky, It turned out to be a blown fuse.
Old Sep 11, 2009 | 11:21 AM
canberk's Avatar
canberk is infamous around these parts
a blown fuse should always be investigated before replacing, fuses don't blow by themselves...
Old Sep 11, 2009 | 12:17 PM
Twincharge's Avatar
Twincharge is infamous around these parts
Very valid point - make sure you replace with the correct AMP rating and if it blows again get it looked at.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
