oil changes
Old Dec 31, 2009 | 05:30 PM
DUTCH VanAtlant's Avatar
DUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud of
Originally Posted by Pepper
What size in mm is the hex bit we need for the drain plug?
On the Transsyberia (GTS Motor) it's a Torx T50. 8mm in-hex is close, but I'd bet you'll eventually strip the socket if you use it.
Old Dec 31, 2009 | 10:34 PM
bbywu's Avatar
Originally Posted by DUTCH VanAtlant
Thanks. In addition to your arguments, follow the money. How much they pay for the oil in bulk at the engine plant also might have some serious consideration.
I'll stick with a brand that I and many other folks trust; and that's Redline. As far as 20k service intervals on the 9 qt sump GTS engine, I'll go for the overkill and do it every 5k w/filter. Cheap insurance.
Just as an FYI...Redline is not a Porsche approved oil.
File Type: pdf
Old Jan 1, 2010 | 08:44 AM
Und so?
Old Jan 1, 2010 | 11:41 AM
bbywu's Avatar
Und so?
...so I suspect you have done some reading about Redline in addition to anecdotal observations. When I researched Redline a year ago, they were unable to provide me with materials data for their non-race engine oils aside from an enormous range for ZDDP (0.6 to 1.2%).
Porsche approved oils (while influenced by marketing) all share something in common. They are all synthetic (for watercooled engines excluding the Cayenne V6), and they all have a ZDDP level of 1000 ppm or greater, if I remember correctly.
Because oil formulation continues to change in favor of decreasing levels of Zn and P (and a greater switch to alternative ash-less dispersants) previously approved oils have either fallen off the list, or were reformulated with a different label. The list is republished from Porsche every 2-3 years. The list I supplied is from 2008.
Depending on how which formulation was used, there were a few white papers discussing Mobil 1's optimal Zn and P levels can range...I can not quote you the exact number, but I know that it was at least 1000 ppm...lower detergency oils requiring less Zn and P. Many Porsche shops have acknowledged that newer SM and CJ-4 motor oil standards are not sufficient for protecting any Porsche engine, hence they continue to recommend Porsche approved oils.
Unfortunately, Redline does not publish their detergent composition of their non race motor oils (or they didn't last I checked...if you have more info, please share.) However, as you said, different brands for different buyers.
For the record, I use a non approved motor oil in my 997TT.
Old Jan 1, 2010 | 12:27 PM
I've used Redline in my MB's for years, with the exception of my CDI Diesel. They do not have an oil that meets the low phos, sulfur and ash specs to protect the diesel particle filter. FWIW, that lower additive spec does not protect gasoline engines as well either.
While Redline does not publish hard formulation numbers, I trust their comments like these:
For the 0W40 Motor Oil: "Recommended for water-cooled Porsche and Mercedes-Benz 229.5/229.51 applications." and "Fully-synthetic ester formula for passenger cars, light trucks, performance vehicles and marine applications."
For the 5W40 Motor Oil: "As specified for Audi, BMW, Mercedes Benz, Porsche and VW applications" and "Fully-synthetic ester formula for passenger cars, light trucks, performance vehicles and marine applications." This is the one I use.
Not hard specs, but my history of excellent success with Redline and the fact that they use the Porsche name in their literature tells me that there is nothing to be concerned about by using their motor oils - and probably their other gear oils, too. The one place I probably would use Porsche fluid is the ATF, as the newer transmissions can be VERY picky about what they have in them.
FWIW, even though Porsche also says that 5W50 is an acceptable weight above -25°C, Redline makes no mention of Porsche in their literature for their 5W50 motor oil.
FWIW, I would never follow Porsche's recommended service interval of 20,000 miles on any oil.
Old Jan 1, 2010 | 02:23 PM
bbywu's Avatar
While we're on the subject, I picked this thread up on the 996TT forum...Dutch, you may want to close your eyes
http://forums.bimmerforums.com/forum/showthread.php?t=1281659
Old Jan 1, 2010 | 02:55 PM
http://forums.bimmerforums.com/forum....php?t=1281659
um Gottes willen!
Old Jan 1, 2010 | 02:58 PM
bbywu's Avatar
um Gottes willen!
lol
Old Jan 1, 2010 | 03:11 PM
That's roughly 6,000-12,000 ppm.
Old Jan 1, 2010 | 06:24 PM
bbywu's Avatar
That doesn't make sense to me as that would be 3 times more than what they put in their race engine oils. I wish Redline would publish their actual formulation as do most manufacturers. It would make it easier for consumers.
Regardless...I am sure Redline is more than sufficient as a choice for engine oil. The reason I brought up the issue of approved oils was to mention that there are formulation issues that do make one oil "better" than others, and each car owner has to choose what fits best for their needs.
Cheers
- bob
Old Jan 13, 2010 | 12:03 PM
Just to keep stirring the pot:
Thank you for contacting Red Line Oil, our products are not submitted or blessed by Porsche but certainly are suitable. Our oils do satisfy various ACEA requirements.
In the older Porsche engines with flat tappet cams some additional anti-wear may be required over the current API SM certified oils 600 to 800 ppm phosphorus limit. The current phosphorus limit for diesel CJ-4, CI-4 oils is less than 1200 ppm phosphorus, not significantly changed from previous oils, an oil submitted initially for the diesel certification should have sufficient ZDDP anti-wear protection for older engines. Our Motor Oils typically contain 1200 ppm phosphorus except the diesel oils which contain 1175 ppm, significant anti-wear protection and sufficient for Porsche engines.
In your Cayenne I would recommend the 5W40, it would satisfy the ACEA A3, B4, E9 requirements or the 0W40 which would satisfy the A3, B3/B4 requirements, I certainly wouldn't expect any mechanical problems nor warranty issues with their use.
Glad to hear the products are performing well in your Mercedes, they will perform well in your Porsche also.
Regards, Dave
Red Line Oil
Old Jan 13, 2010 | 08:27 PM
bbywu's Avatar
I think you've proven my point. Redline reports 1200ppm ZDDP, not the 6,000-12,000 ppm as calculated by the % they listed. This would fall in line with the oils that are approved by Porsche. I mentioned "approved oils" in my previous post because this information was simply unavailable...and a large number of owners who do DIY oil changes purchase oils without knowing the specifics of what they are putting in.
I think we're all more informed now about Red Line, thanks to your research. Thanks!
Old Jan 15, 2010 | 01:29 PM
Enilder's Avatar
Enilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond repute
poor bimmer.
thx for info on redline oil.
Old Jan 26, 2010 | 05:25 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
Original aluminum plugs are 8mm. A good solution for the easily stripped original plugs is to replace them with magnetic plugs from LN Engineering. These plugs are hard anadized, have magnet insert and use 10mm hex--$20 each.
Old Jan 26, 2010 | 06:37 PM
On my 2010 Transsyberia (GTS V8 Engine), the plug is very close to 8mm in-hex; but it is exactly a Torx T50.
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
