2006 CV6 with cold start engine shake
Old Dec 13, 2009 | 08:24 PM
twiskus's Avatar
twiskus has a spectacular aura abouttwiskus has a spectacular aura abouttwiskus has a spectacular aura about
My wife's cayenne only has about 27k on it, but about 5 different times on a morning cold start, I will notice her engine will shake quite harshly for about the first 5 seconds of operation, then smooth itself out. The car is under factory warranty, so I don't have concerns there, but I am not sure in this vehicle what would cause it...I doubt a cold start solenoid like I had in my RX7TT, but I am not sure. Any experience with this, or should I chaulk it up to the fact it's VW's engine ? I am excited that the new V6 for the next gen will be a Porsche developed, non-shared V6!
Trev
Old Dec 17, 2009 | 09:22 PM
twiskus's Avatar
anyone with thoughts on this??
Old Dec 17, 2009 | 10:39 PM
GoldenPEPPA's Avatar
GoldenPEPPA is infamous around these parts
Btw, there's NOTHING wrong with that engine... lol.
It's the 3.2L VR6 from the VW bin. It's proven to be quite reliable and I'm sure it's something minor that can be wrapped up at the dealer. I wouldn't be so confident that the P-V6 would be better
Oh and btw... with $5000, a cylinder head spacer, T35 turbo and 15psi of boost this engine will lay down 450hp at all 4 wheels...
Old Dec 23, 2009 | 07:22 PM
dtran023's Avatar
dtran023 is infamous around these parts
I have an '09 V6 and it's doing the same, shakes a bit and calm down smoothly. I brought it back to the dealership and they told me it's normal for the V6 to do that, they also checked out another V6 and it did the same. I hope this help and somebody can verify this.
Old Dec 28, 2009 | 12:16 PM
elcayano's Avatar
elcayano is infamous around these parts
V6 Cold Start Shake
Same issue with mine. Dealer said it had to do with gasoline being too dirty and blocking the injector needles or something. He said he reprogrammed the CPU and recommended pouring fuel injector cleaner once a month when filling up tank.
Next time you fill up, try a different gas brand.
Old Jan 3, 2010 | 02:03 PM
jsc1m3's Avatar
jsc1m3 is infamous around these parts
Hi guy's i am new to this forum but have been a Porsche tech since 2002, the V6 cayenne engine shake is normal on cold starts, it can even make some rattling typr noise. This is a result of the secondary air system acitvating causing the fuel mixture to rich'en upand get the catalytic converter warmed up. If the shaking worsen's it can also be an ignition coil there is updated coils for the V6 too now but there is usually a check engine light followed by severe shaking. Hope this helps
Old Jan 4, 2010 | 08:21 PM
twiskus's Avatar
Thanks for the information! It's great to have someone who knows what they are doing chime in. Are the updated coils a TSB or just a customer pay scenario? Would you say the 3.2 is a good solid motor?
Trevor
Jul 29, 2019 11:13 AM
GrantRR
Jun 28, 2018 03:33 PM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
