Control PCM luminosity
Old Dec 29, 2009 | 09:56 PM
ian1975's Avatar
ian1975 is infamous around these parts
Smile Control PCM luminosity
Hi!
Is it possible to control the luminosity of a PCM 2.1 like brighter?
Thanks!
Ian
Old Dec 30, 2009 | 04:44 AM
DUTCH VanAtlant's Avatar
DUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud of
Originally Posted by ian1975
Hi!
Thanks!
Ian
Not sure about 2.1, but here's the sequence for PCM 3. Maybe they're similar:
INFO->OPTION->SET PCM->Display->Display->Brightness. Then use the up and down arrows to set the brightness.
In PCM2, it can only be done in the Map Mode. See the attached file.
(PS - If you become a contributing member at Renntech.org, the Owner's Manual is available for download.)
File Type: pdf
Old Dec 30, 2009 | 01:49 PM
ian1975's Avatar
Thank you, it's working.
Ian
davetherave
Bentley
Sep 11, 2015 04:15 AM
