2009 cayenne s coolant low
Old Jan 31, 2010 | 09:23 PM
jyupitt1's Avatar
jyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond reputejyupitt1 has a reputation beyond repute
Hi,
Today the "check coolant level" light came on. I immediately stopped at a gas station and added some coolant/antifreeze. My car only has 8900 miles, have heard about earlier models having tubes/pump issues.. But is it normal have have low coolant level at 8900 miles??
Old Jan 31, 2010 | 09:49 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
Definitely not normal. Take it to the dealer. You're also not supposed to mix coolants, so the radiator may need flushing.
Old Feb 2, 2010 | 11:16 AM
medtech's Avatar
medtech is infamous around these parts
How low is low?
When you looked at the reservoir was it bone dry, or just at the low mark?
Usually, a bottle of Redline "Watter Wetter" and a cup of distilled water is all that's needed to top it off. With that small amount, adding antifreeze isn't even an issue. And yes, the WW is compatible w/ AF.
Old Feb 2, 2010 | 12:14 PM
jyupitt1's Avatar
Originally Posted by medtech
How low is low?
its below low mark. my dealer wants to take it in immediately, as they suspect it's a leak.
Old Feb 2, 2010 | 01:08 PM
canberk's Avatar
canberk is infamous around these parts
there's a bulletin to replace the o-rings of the coolant system. the pressure test may come out negative, since the pressure activates the o-rings and it may seem that there's no leak, but when the pressure is gone, o-rings will start leaking back, tell your dealer to not to pressure test the radiator.
Old Feb 2, 2010 | 03:32 PM
jyupitt1's Avatar
thanks for the heads up!
Old Feb 2, 2010 | 10:38 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
Having only 8900 miles ,it may have been low to begin with and not caught during the PDI inspection at the dealer.
Tomp
Jan 5, 2021 11:59 AM
Perkman87
Nov 19, 2015 05:31 PM
993 Guy
Sep 4, 2015 07:48 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
