Bypass pipes help!
Old Dec 28, 2004 | 09:16 AM
renntech36's Avatar
renntech36 is infamous around these partsrenntech36 is infamous around these parts
Bypass pipes help!
If I have magnaflow mufflers on my Cayenne Turbo now, how much louder will it get with the bypass pipes installed. I really am just looking for more performance. The exhaust as is is decently loud, and I really would not like it much louder.
Also, is this a hard install? Does it require welding.
Lastly, will this open up the sound of my turbos any? I know my exhaust did, and especially on my last truck with no muffler the turbos were ridiculously loud.
Thanks and appreciate any help you can give me!
Harris
Old Dec 28, 2004 | 10:13 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Re: Bypass pipes help!
Harris
I don't think it will be much louder. Yes, it's a performance thing and you can expect 25 additional hp by removing the secondary cats.
Install is simple bolt on. The top flange bolts on each side are tuff to get a wrench on. It is recommended that you slide back the clamp that attached the cat exit pipe to the muffler entry pipe so that the cat can be moved a bit to gain access to the top flange bolts. The bellows that attaches to the flange is flexible allowing you to move/shift/tilt the cat so that you can access this troublesome bolt...
Old Dec 28, 2004 | 09:44 PM
TCM's Avatar
TCM
TCM is infamous around these parts
It gets a lot louder. Install should be relatively simple, but expect quite a jump in sound difference. You may want to pm DEETZ for his thoughts. He is running the bypass with the TechArt exhuast is loves it, but says it is definately very loud. Hope this helps.
Old Dec 29, 2004 | 05:54 AM
rockitman's Avatar
Yeah.... it's a lot louder with a NA Cayenne S...Not a turbo. Two different animals...like apples and oranges in terms of sound.
Old Dec 29, 2004 | 07:03 AM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
I heard deetz car. Its a lot louder, and i mean a lot lol
Old Dec 29, 2004 | 07:53 AM
rockitman's Avatar
Right, but this guy has a Turbo, so how DEETZ' car sounds has no bearing on a sound decision for a turbo owner. Turbo's are much quieter than a NA variety Cayenne to start with...
Old Dec 29, 2004 | 08:10 AM
TCM's Avatar
TCM
Sorry, did not see it was a Turbo we were talking about. I would still think it would be louder but to a muhc ore muffled degree then the S due to the turbo.
Old Dec 29, 2004 | 02:32 PM
renntech36's Avatar
well i think i am going to order them on Wednesday (tomorrow). Rockitman, how much performance difference did you notice? I mean, seat of the pants, is there an impressive difference?
Old Dec 29, 2004 | 04:00 PM
rockitman's Avatar
I was breaking the CT in when I changed over to them, so I didn't get a WOT test compare when stock and when not. It feels peppier "no pun :-)" but I think the throttle response is better along with less t-lag. I have not had a chance ("cold up here") to put in my free flow air filters yet (K&N), nor my hyperboost diverter valves... I will probably get the Fabspeed supersport exhaust in the Spring and I will be done with close to 500 Hp with no ecu tweak... Considering you were running straight pipes last time (I think that was you???), I don't think you will have a problem with the additional sound by dropping the 2nd dary cats...
Old Jan 2, 2005 | 11:24 PM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
I am not sure why but my exhaust sounds much deeper and louder with the fabspeed pipes. As you know, the techart muffler broke and I had it replaced and I put the fabspeed pipes together with the new muffler. The first 500 miles it sounded very rough and loud, it is now alot deeper and no resonance at all and more quiet
pwdrhound
Sep 13, 2016 10:44 AM
Sales@RSW
Sep 16, 2015 06:03 AM
maroli
Sep 15, 2015 07:07 PM
