Looking into buying a winter wheel Setup ..
Old Mar 1, 2010 | 05:17 PM
RojoGTS's Avatar
RojoGTS is infamous around these parts
Would a set of 19" wheels be the best for winter setup, Right now I have the factory 21"s
Old Mar 1, 2010 | 06:22 PM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
hands down just talk with Damon at tirerack, he knows everything regarding winter setups and hes a gentleman
Old Mar 1, 2010 | 06:52 PM
SLATETT's Avatar
SLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to beholdSLATETT is a splendid one to behold
I have a 19" set on my CTTS - works awesome.
Old Mar 3, 2010 | 01:29 AM
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
I prefer 18's but I don't see any cars listed for you so I can't advise. On the CT and lower one can use 18's. However, if you have a CT with the factory Turbo Boost Kit or a CTS, you can only go down to 19's.
What do you have?
Old Mar 3, 2010 | 02:08 AM
Flyingpig1's Avatar
Flyingpig1 is infamous around these parts
I seem to see more winter setups with 18's. There are usually some good deals on OEM 18's and 19's in the Sale section. I have 18's and they worked great in all the snow we had on the east coast this winter.
Old Mar 3, 2010 | 10:09 AM
RojoGTS's Avatar
Yea im pretty sure I cant go with 18" some I am going to look into a 19" setup..
Old Mar 7, 2010 | 09:25 AM
996gt's Avatar
996gt is infamous around these parts
agreed
996gt's Avatar
best place to buy?
Old Mar 7, 2010 | 01:31 PM
gr8ful's Avatar
GTS uses the same brakes as the Turbo. I don't know why you couldn't use 18's. I know of good 18" snow & ice tires but I do not know if anyone makes a really good 19 snow & ice. While I use 255/55-18, long time Alaskans are encouraging me to go with 235/66-18's. Certainly when the roads are clear the wider tire helps get the Turbo power to the road but when the raods are choppy or on deep fresh snow, the narrower tire gets down more on the road. There is a trade off. I don't use studs but may get studded tires next time. This winter has been so variable that we've had a lot of ice as temps range from 11 to 48 F!
Old Mar 7, 2010 | 02:16 PM
skier's Avatar
skier is infamous around these parts
I have an 08' GTS, bought 18" OEM S rims from a guy on here, powder coated black, mounted with Pirelli Scorpions snow & Ice.....drives like a snowcat on everything.
Old Mar 7, 2010 | 04:57 PM
SLATETT's Avatar
Not sure what the winter setup is going on - but 19 inch is the smallest diameter you can put on a 2009 Cayenne Turbo S
Old Mar 7, 2010 | 05:19 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
I have 21" SportPlus wheels on mine with the Pirelli Scorpions from Damon@TireRack. 21's are fine on the snow with the proper tire, but I can't argue with 19's either.
Old Mar 8, 2010 | 01:46 AM
gr8ful's Avatar
Yes, but a CT or GTS both use the same brake and 18's will fit.
On the CTS and on those rare CT with the factory Turbo Boost Kit the brakes are larger and nothing smaller than a 19 will fit.
Old Mar 8, 2010 | 05:50 AM
rubin's Avatar
rubin is infamous around these parts
This winter I ran the new Blizzak DM-V1 (255-55-18) on my '09 CS and it turned my Pepper into a gawd dayum snow leopard!! The stock Conti 4x4's were absolutely WORTHLESS in even 2" of snow. I couldn't get up my driveway in 4-low and locked. With the Blizzak's it really was like the hand-of-god was moving my truck. They cost me $750 on the truck; worth every single penny.
You give up quite a bit of cornering ability since the deep and soft tread makes turns feel "squishy". However, once the white stuff is failing and you're driving through 2-FEET of snow you'll know it's worth it.
Old Mar 8, 2010 | 06:42 AM
damon@tirerack's Avatar
Moderator
I'd love to help, and we still have inventory left. Please give me a call.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
