temp gauge moves
Old Mar 23, 2010 | 03:41 PM
TurboSPeng's Avatar
TurboSPeng is infamous around these parts
temp gauge moves
hey guys
On My 06 Turbo S the temp gauges moves from 180 to about 220 after about 30mins + of regular driving. wondering if other turbo peppers do the same thing or i might have air in the system.
After driving for awhile even in 30 degree weather..truck seems to run very hot. i will notice the temp gauge moving when i'm at stop and go traffic and idle but it does go back down it never pass 220-230 degree.
At idle it will go down normal and then go back up and go back down in 10 mins.
i don't recall truck acting like that last year. now since the weather got warmer it seems to act like that every time i drive.
i heard that turbo peppers run hot and if driven hard it can goes up abit but my is doing it almost every time.
thanks in advance for any input.
Old Mar 23, 2010 | 06:46 PM
Justahonda's Avatar
Justahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud of
I would check your waterpump. Notice any leaks from the car? Tomorrow morning when you start it listen under the hood for a louder than normal whistle
Old Mar 23, 2010 | 06:47 PM
Justahonda's Avatar
They are very common to go. Depending on your mileage you may have already replaced it once.
Old Mar 23, 2010 | 07:39 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
or coolant pipes. They have been a known issue on the 955 Cayennes.
Old Mar 23, 2010 | 09:04 PM
Justahonda's Avatar
Correct. Along with the engine itself being prone to drinking coolant. Always keep an eye on the level in the reservoir. I'm sure it will always need to be topped off
NC 996TT
Mar 23, 2023 06:19 AM
BLKMGK
Sep 19, 2015 03:51 PM
jpik2003
Sep 10, 2015 05:18 PM
sparks
Sep 8, 2015 03:03 PM
