Tow Package
Old Mar 29, 2010 | 05:38 PM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Tow Package
I just added a 2010 Cayenne Transsyberia. It came with a tow package already installed. The 7 pin connector is covered with a plate. What do I need to buy for wiring. Some sort of a plug cover/outlet. I want to avoid the dealer so do not get screwed. Suggestions on web sites with what I need to buy. Also, what size ball should I get (2 inch?) for the hitch.
Old Mar 29, 2010 | 06:34 PM
medtech's Avatar
medtech is infamous around these parts
I would try Sunset Parts in Oregon or Suncoast in Florida.
Search the other forums for specifics as far as matching the Porsche harness to whatever you are towing.
Old Mar 31, 2010 | 05:18 PM
cmoore1's Avatar
cmoore1 is infamous around these parts
The part you need is PNA-955-118-93 list price $17.50 Sunset price $12.08.The wiring harness plug should be behind the blank plate it just plugs in to the back of the above noted part.
Old Apr 2, 2010 | 01:29 AM
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
You want the OEM part. My dealer had to order mine from Germany. Since it (the trailer) becomes part of the alarm system, you really want a Porsche part.
The 2" ball has become the standard. While you might be able to get away with someone else's part, the POrsche tongue & ball are reliable. I'd rather be safe & secure than try to save on those parts.
Old Apr 2, 2010 | 05:15 AM
thor7000's Avatar
thor7000 is infamous around these parts
As mentioned above, get the OEM plug...takes about 3-minutes to install. Also, depending on what you are towing the standard ball size is 2-inch, but if towing heavier/larger items go to 2-5/16 ball size.
Old Apr 6, 2010 | 01:38 PM
ERSKATEDOC's Avatar
Got the plug and hitch
Thanks for the info
Ps- I love my new 2010 Transsyberia. Im driving it more than the TT
NC 996TT
Mar 23, 2023 06:19 AM
VID997
97
Mar 20, 2018 02:23 PM
pwdrhound
Sep 13, 2016 10:44 AM
jonate24
Oct 25, 2015 11:34 AM
carbonjim996TT
Sep 20, 2015 08:14 AM
