my 2005 Cayenne S has no A/C!
SubscribeI was just reading the thread about climate control delay. I wanted to check how long my climate delay was on my way home. I turned on my a/c and no air is coming out of the vents. I played with all the hvac buttons and still no air. Display works fine but no air is blowing out. Help!
Had my 04 fixed twice! Center vents would stop blowing air then they would start to work then the outside/end of the dash would stop. A real PIA in the middle of the summer. There are several control modules that where replaced each time...big labor job but fortunately it was under warranty!
Good Luck.
Good Luck.
I turned off the car and started it back, still no a/c. I turned it off again and this time I took the key out, open the door and then started it again. This time a/c worked fine. Very strange. Could there be a part that is about to go bad? I have 1.5 months left on my CPO.
