TPMS Question
Old Nov 19, 2010 | 07:59 PM
cs s60's Avatar
cs s60 is infamous around these parts
TPMS Question
My father in law is away and let me use his Cayanne for a few days while my truck was getting fixed. It was filthy, so yesterday I decided to give it a good wash before taking it back. It looks great, but now the TPMS lights are on. On the picture of the car in the mesage center in the dash (where u scroll thru the radio/ nav/ etc) it didn't dispaly anything for the front tires, and 3-4 psi on the rears.
It drove it tonight, and the warning lights still come on with the same readings on the picture of the car. When I scrolled thru the message center, and came back to the picture of the car and the psi, they were all displaying the correct psi (same as before I washed it), but the TPMS lights were still on.
I have other cars with TPMS (non-Porsche) and never had an issue after washing. Does it just need time to dry out, although I'm not sure how washing caused it?
TIA
Old Nov 19, 2010 | 08:12 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Check the TP values on the door to ensure you have proper inflation, you could just be down a couple of lbs on the back...
-Eli
Old Nov 19, 2010 | 08:23 PM
cs s60's Avatar
I don't know why I never thought of that... IIRC, it was showing 34 in front and 30 psi rears, but I'll check it out when I can.
Old Nov 19, 2010 | 09:11 PM
RobsCountach's Avatar
RobsCountach is infamous around these parts
I think the rears should be closer to 40. I know the pressures are something I NEVER run mine at, so disabled it.
Maybe washing it cooled the air in the tires down - Probably just coincidence.
Old Nov 20, 2010 | 07:19 AM
spinny02's Avatar
spinny02 is infamous around these parts
On my 08 ctt. 39 psi in front 49 in rear w 20" porsche sport tech rims.
I had the same issue I just needed to fill the rears.
Old Nov 20, 2010 | 01:34 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
I run 35 fronts 45 rear
Old Nov 20, 2010 | 07:26 PM
cs s60's Avatar
I think they are 18" wheels, but I'll check the psi as soon as I can. Thanks for the help.
Old Nov 21, 2010 | 08:53 AM
4flynlow's Avatar
4flynlow is infamous around these parts
I am curious as to why the rears are inflated 10 lbs more then the front?
Old Nov 21, 2010 | 09:21 AM
George718's Avatar
George718 is infamous around these parts
That makes 2 of us. The CS doesn't run a staggered setup.
Old Nov 21, 2010 | 11:06 AM
Its ridiculous and why I don't use the TPMS. Like most, you can not 'set' the pressures it looks for; its pre-set.
I run 32 front AND rear. Runs just great at 8 or 80 mph. Handles and rides better too.
Old Nov 24, 2010 | 08:14 PM
cs s60's Avatar
Turns out he was having problems with the sensors before, and has to take it in.
BlueTurboS
Aug 4, 2020 08:24 PM
zx5go
May 27, 2016 10:09 PM
AUDIRS6
11
Oct 8, 2015 12:21 PM
Fabspeed Motorsport
Ferrari
Sep 1, 2015 09:31 AM
