Squeeky Brakes on new CTT
Old Jan 18, 2011 | 04:55 PM
Overdraft's Avatar
Overdraft is infamous around these parts
Anybody experiencing squeeky brakes on their 2011 Cayenne Turbo? Mine was delivered Friday - its' been brutal for three days. The weather is cold here but man...getting on my nerves. Before I bring it in any comment?
Old Jan 18, 2011 | 05:25 PM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
Does it have pccb? My '08 tt has pccb and they hum and then they squeak. I took it in today and they said that I used tired dressing. But check this out, since the last time I had my car detailed at the dealer, they said the same thing, not to use tire dressing and they did just that. So when I brought it in today, they blamed it on the tire dressing again. So they went and cleaned that out. I'll just wait and see if it squeaks again. Believe me, that's not how I want to draw attention to my yellow calipers. Quite embarrassing. When you take your car in chances are, you will get a handout about Porsche brakes and that it's "normal" for it to squeal. As John Stossel from 20/20 would say "give me a 'brake'!"
Old Jan 18, 2011 | 07:28 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
maybe they need to be bed, normal brakes squeek when they are new..
try some high speed stops with 80% on the pedal but let off before it stops and dont hit ABS... 10x from 60-80mph to get em hot... and then drive it around after and maybe will quit the squeal...
my brakes did this when new on carrera (non ceramic) and "bedding" them fixed it... u can google "bedding" the pad's
Old Jan 18, 2011 | 09:24 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
ditto on the bedding and ceramics even if not OEM always are scratchy by nature, its their performance when heated or under heat that is above the rest.
I remember as a teenager playing baseball, I got a ceramic bat...........that was awkward because moms ceramics always broke so easily under my command
Old Jan 20, 2011 | 05:10 AM
Overdraft's Avatar
Thanks All - 'bedding' makes perfect sense - will try that....
BonitaBeast
Cayenne 955/957
11
Oct 16, 2015 06:14 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
