Check Engine Light.....Please Help!!!
Old Apr 3, 2011 | 07:37 PM
ginatom's Avatar
ginatom is infamous around these parts
Question Check Engine Light.....Please Help!!!
Let me start by saying I know very little about cars but I hate taking my car in for repairs and not know what they're saying or understand what needs to be done. This past Friday evening my check engine light came on & after reading a few threads on this site I checked my gas cap & then I took my 05 Cayenne S to a national auto parts store to have it checked. The report came back with the following:
1. Definition: Randon cylinder misfire detected
Explanation: Lean Air/Fuel ratio
Probable cause: 1. Ignition system misfire condition 2. Fuel Injector Fault 3. Engine Mechanical Condition
2. Definition: Cylinder 5 Misfire Condition
Explanation: Vacuum leak on engine
Probable Cause: 1. Ignition system fault. 2. Fuel injector fault 3. Engine mechanical condition
3. Definition: Cylinder 4 Misfire Condition
My nephew works for this auto parts store and said my car needs a tune-up. He suggested I purchase my parts from him/ his store @ his associate's discount & have the Porsche dealer do the work. So my questions are:
1. Will Porsche allow me to supply my own parts & I pay for labor only.
2. Will a tune-up solve my problem or is there something else wrong with my car?
Thanks in advance for your thoughts, suggestions or advice.
Don't Want To Be Helpless In St. Louis,
Old Apr 3, 2011 | 08:41 PM
airbrush1's Avatar
airbrush1 has a spectacular aura aboutairbrush1 has a spectacular aura about
I believe that the ignition coils are a common issue on the cayenne, mine were replaced under warranty.... someone else may be able to offer more info however
wish I could be of more help, but a search regarding ignition coil issues may yeild some more answers!
Old Apr 3, 2011 | 11:43 PM
Markenstein3D's Avatar
Markenstein3D is infamous around these parts
there's a recall on the coil packs for cayenne's. call/check with your porsche dealership first, explain to them the errors you got and that your CEL in on.
Old Apr 4, 2011 | 12:46 AM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
sounds like coils..
Your better off letting the dealer use their parts.that way if there is a problem they will have to warranty it.
Old Apr 4, 2011 | 09:26 AM
ginatom's Avatar
Thanks for the info. I spoke with Porsche dealer this AM & they said the warranty only applies if the coils in my car are not the original inigition coils. Since I purchased this car as a pre-own I have no idea whether the previous owner replaced them or not. (Shouldn't they have access to that info?) Therefore, I will need to pay to have them replaced and if they wear out again the warranty will apply. This makes no sense to me & if this was a true recall why should I pay to replace a recalled part. Has anyone else had this experience?
Old Apr 4, 2011 | 10:08 AM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Because the recall covers a different part number of coils than the original ones that were installed at the factory. If they were replaced after the factory ones they would have the part number of the coils under the recall thus making you eligible for replacement at no cost to you.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
