955 Turbo buyers guide
Hi all,
Newbie to this forum looking for a little advice.
I am currently in the market to purchase an early 955 turbo (2003 -2005). From the research that I've done so far the main issue seems to be the coolant pipes and ensuring they've been changed to metal items.
What other items should I be looking for when inquiring about these vehicles? Are there any other component that should have been replaced during its life that are prone to failure?
Is there a definitive buyers guide on here?
Thanks in advance
Aki
Thanks in advance
Aki
Also is the water pump a service item that would be changed by the dealer as a precaution or is this part prone to failure?
Oil leak found on inspection
I went and viewed 2 CTT yesterday. I took an inspection camera from work with me so that I could get into the tight spots to check if coolant pipes had been changed etc. One thing I did notice with both cars was that they appeared to have an oil leak from the left hand side of the engine. Even with the camera it was difficult to locate exactly where the oil was coming. It looked like it may have been coming from an oil pipe that runs to turbo but I cant be sure? In contrast the right hand side of the engine on both cars was dry and there were no traces of oil leaking.
I was surprised to find both cars had the same issue. Is this a common problem with these cars? Has anyone experienced similar issues and if so what did you track down to be the cause?
