Went drag racing Friday night
Old Jul 10, 2011 | 04:51 PM
NovaPS's Avatar
NovaPS is infamous around these parts
Took my 06 CTTS to Union Grove in wisconsin. Came right off the 20 mile drive hot and lined up and ran 13.81 in about low 80s temps. Hot lapped it 3 times in a row best was 13.71. Let it cool down for about an hour and ran 13.54, 13.45, and then 13.37 at about 830 pm after temps had dropped to 71F or so. Best 60 foot was 1.97. Best result was lining up in manual 1st gear, brake boost to about 2100 RPM and let if fly shifting manually at about 6000rpm.
Just running a baseline but I was pretty pleased with those times. My goal of being solid in the 12s after an ECU tune, 2ndary cat bypass, intake, Plenum seems achievable with those bone stock numbers.
Just put the JB4 and DCI in my 335 as well, so heading up again this week to run that after a 13.60 baseline in stock trim. Looking forward to cooler weather for both cars
Old Jul 11, 2011 | 07:23 AM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Cool. Good data point for the S.
Old Jul 11, 2011 | 10:39 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
I have heard that when you brake boost (apply hydraulic brake and press accelerator simultaneously) the ECU apparently down tunes the engine power.
Old Jul 13, 2011 | 07:03 AM
the head's Avatar
If you build up enough boost, it will indeed close the throttle on you. I figured out that you can floor the throttle once the first amber lights up and by the time you launch, it will not shut down and give you just a little better launch due to a slight increase in boost off the line - but we're talking hundredths of a second.
Old Jul 13, 2011 | 08:26 PM
bartown's Avatar
bartown is infamous around these parts
nice times
Old Jul 17, 2011 | 07:47 PM
es201nj's Avatar
es201nj is infamous around these parts
Great times for stock runs
Old Feb 18, 2014 | 10:03 PM
dugahole55's Avatar
dugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of lightdugahole55 is a glorious beacon of light
What did you get for wheels, and what are the offsets and rim widths
thanks
turbotuner20v
Sep 11, 2015 12:02 PM
