Front Brake Recommendations?
Old Aug 17, 2011 | 07:50 PM
atp160's Avatar
atp160 is infamous around these parts
Hello All,
Getting ready to put new front brakes on my wife's 2004 Cayenne S. It has the silver brake calipers. I know there are red and black calipers also and that means something. I think the silver calipers means the size of the rotor being 350 mm? Any recommendations on rotors, pads and size would be greatly appreciated. I've changed brakes on my other cars with no problems (BMW's) Do I need anything special? Should I replace the sensor cable also? Is there one or two? Thank you again.
Fred
Old Aug 17, 2011 | 08:27 PM
rriva's Avatar
rriva is infamous around these parts
I was going to do the same thing until I was told that the rotors are not turnable. So, oem rotors, pads, and sensors (did not need to change sensors) all the way around was the way I went at 25kmi. (just had the dealer look at them for the 40k service and still good.)
Old Aug 17, 2011 | 08:35 PM
Dennis C's Avatar
Brakes are pretty easy on the Cayenne. You can measure the rotor thickness with a caliper to see if they are still within spec, and do a visual inspection to determine if you can do only the pads. On my first brake change, I did pads and not rotors. If the brake workshop warning has illuminated, then you'll need to change the sensors too. That's easy, and sensors are pretty cheap.
In first gen Cayennes, the silver calipers of the CS and the red calipers of the CTT are identical with the exception of paint color. The CTTS has bigger red calipers. The black calipers from the V6 are smaller.
Old Aug 19, 2011 | 10:30 AM
seankrider's Avatar
seankrider is infamous around these parts
+1 on pads and/or rotors being quite easy on this car.
I usually get away with just pads in the front every other time the sensors go off. So rotors and pads, then pads, then rotors and pads, etc.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
