Champion lowering module
Old Oct 19, 2011 | 09:49 PM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
Anyone install this yet? Having trouble, triple checked my wiring and I'm getting suspension warning and can not adjust. Just wondering if others have had any luck. Will call Tom tomorrow.
Old Oct 26, 2011 | 02:12 PM
pwjk12's Avatar
pwjk12 is infamous around these parts
have you checked the battery? mine was doing the same thing when the battery was dying.
Old Oct 26, 2011 | 05:15 PM
powderjay's Avatar
Having some work done on her at the dealer. Headlight issue. Will have the check the battery
Old Nov 1, 2011 | 11:14 AM
powderjay's Avatar
Still at the dealer so I haven't had a chance to check her out yet. Will update when I get her back!
Old Nov 4, 2011 | 06:27 PM
powderjay's Avatar
Got the car back disconnected the battery for apx half hour. Reconnected, cycled the key then started. Got a faulty suspension workshop message on the display. I'm sure this is why the module is not lowering the car to desired level. Not sure why it's throwing the code as wiring has been triple checked and factory adjustments still work. ??
Old Nov 28, 2011 | 03:23 PM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
Did you ever get this issue resolved? What was the culprit?
Old Nov 28, 2011 | 03:39 PM
powderjay's Avatar
Unfortunately no. Dealer was supposed to clear any codes last time I was in for service but not a 100 percent sure they did. The car is only dropping about 3/4 of an inch lower than stock. It is lowering just not as much as it should. Taking it to an independent on thur. And I'll have them check for any faults that may be causing the problem. Really need this lowered, love the look at loading height. Will update when I know more.
Old Nov 28, 2011 | 03:53 PM
GTS Jay's Avatar
Sorry to hear that. Thanks for the update though & yes, please do keep us posted. Best of luck!
Old Dec 1, 2011 | 11:10 AM
powderjay's Avatar
No codes, No luck. Spent a lot of money for a 3/4 inch drop
adnanm3
Nov 22, 2023 02:43 AM
dgreen78
Feb 29, 2016 11:28 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
sparks
Sep 8, 2015 03:03 PM
