Air compressor advice/suggestions
The air compressor in my CS does not work... and takes forever to fill up. Porsche wants $270 for a new compressor.
What do you guys suggest an alternative would be? I was thinking of this one but am not sure if it would fit in the CS compressor area.
http://www.griotsgarage.com/product/...+compressor.do
I want one that I would like to use once a month to check tire pressure on the vehicle, so it should be a good reliable one that can take once a month air filling task.
Thanks...
-Aiyer
Thanks...
-Aiyer
Are you sure it's the compressor? There's a rebuild kit that you can buy and install that is cheap and easy that helps when the compressor is taking too long to adjust the vehicle height.
Dennis C: It is not the suspension air compressor. I should have said Tire inflation kit compressor.
After I tried to inflate my kid's stroller this past weekend, it sure looks like it is a goner. Does not fill up those tiny tires at all. I just need to have one so I can inflate tires to proper pressure once a month instead of filling at the gas station.
Here is one on ebay you can probably get for about $100 with shipping or less.
http://www.ebay.com/itm/Porsche-Caye...#ht_500wt_1180
