Check Engine Light Lit Up After Intake Installed
Old Apr 25, 2012 | 12:19 PM
garukun's Avatar
garukun is infamous around these parts
I was finally able to complete the intake installation last night, I can't describe how much joy I had at that moment. The thing that gave me the most issues is the lil air suspension hose. It doesn't like to connect to bind to the little tip tightly. And I still didn't know how I was able to get it on tightly now as the physics inside does not make sense to me whatsoever.
Anyhow, while driving on freeway today, my check engine light lit up. Is this supposed to be normal? If not, any tips on where I should be checking for this problem? I'm pretty sure that the pipes were clamps pretty securely (with the exception of maybe the air suspension). I dont wanna kill my engine for just an intake....
Any tip is helpful! Thanks!
Old Apr 25, 2012 | 01:35 PM
ECS Tuning - Porsche's Avatar
I would see what the trouble codes are and fix from there. Have someone check them and report back.
Old Apr 25, 2012 | 01:50 PM
ExEngineer's Avatar
ExEngineer is infamous around these partsExEngineer is infamous around these parts
^^^ Seems like the best advice. I'm going to bet that one of the MAF connectors is loose or the sensor got damaged - but that's a totally uninformed opinion.
Old Apr 25, 2012 | 02:01 PM
garukun's Avatar
Will I have to buy one of those OBD things to diagnose it? I noticed that the wiring harness for the MAF sensor is a bit too close to the engine, would that cause any short circuits?
Old Apr 25, 2012 | 02:36 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Doubt that little filter for the air suspension would cause that. But it could be a MAF sensor issue. Check the connections again. Its possible that one is loose. Let us know!
And yes they are pretty close, close enough for the serpentine belt to rub it if its not clocked correctly.
Old Apr 30, 2012 | 11:11 PM
garukun's Avatar
I got some readings from Durametric tool, it's 0021. I did google this code, all come back as P0021. Are the two the same thing?
Old May 1, 2012 | 08:56 AM
03EvoIII's Avatar
hey there. So is it running ok? camshaft timing error correct? Try a battery reset to see if it clears. If it doesn't then possible camshaft sensor issue.
Old May 1, 2012 | 04:09 PM
garukun's Avatar
The car seems to drive fine. But i'm not sure if it's camshaft timing, because I wasn't sure if 0021 is the same as P0021. I will try to reset the battery this weekend and see if it clears it up. Thanks for the tip. I am still convinced that it's somewhat caused by the intake that I have installed...
Old May 1, 2012 | 11:04 PM
03EvoIII's Avatar
I understand what you are saying. I think I asked before, but you have checked all the hose couplers? no leaks right? Did you take the MAFs completely off? Try the reset or have it cleared..maybe it was a just a hiccup and won't come back. Good luck and let us know.
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Nissan GTR
Aug 19, 2015 02:11 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
