Porsche Entry and Drive Question
The other option is buying an official Porsche PIWIS which I'm sure you can use to program these kinda stuff but it's quite expensive to say the least.
Bought the latest version. Haven't gotten it yet, will get it mid this week.
In other news I have a CEL and most likely the P0441 EVAP code, which I will get to confirm when I get it as well
Bought the Durametric and bad news. So far I have not seen any options for coding modules for the Cayenne. Emailed Durametric and they cannot tell me if the device supports any coding on the Cayenne.
Okay....so the sun finally came out and i went out and played with the auto lock feature....here is what I did...
1. Turned car on...and went to setting to disable auto lock and auto unlock doors and tail gate.
2. Turned car off and went away from the car....Never heard the car beep to signal it was locked....
3. Turned car back on... turned all the setting back to normal. Put the key in my pocket and walked away.
4. Less than a min later I heard my car beep and it was locked
Ohh and just to add something that I don't know if it is related to this or not....but when I use my other key fob it doesn't act the same way. When I use my other key fob to lock the car I don't get the signal beep or anything...just the normal lights blink... Not sure about the auto locking with my other key fob because i just keep it at home incase i misplace my key...Don't know if any of this helps you out....
edit:
Ohh...And I am not sure if it is really a distance thing or a timing issue...that wasn't something that I really checked....I just always assumed that it was a distance thing because in my mind it is cooler that way...HAHAHA....plus when i park my car in my garage I leave the keys in it, and it doesn't lock the car while they are left inside...
edit:
joseph_number1
Jul 19, 2018 05:45 PM
