How do you replaced Parking light bulbs in the Head light units?
Old May 19, 2012 | 02:44 AM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
How hard is it to replaced the parking bulb lights in the headlights? It's the smallest bulb to the farthest corner of the headlight units. Please help. Thanks!
Old May 19, 2012 | 08:10 AM
Dennis C's Avatar
They are quite simple to replace. Look in your owner's manual for instructions on the procedure to remove the headlight assembly and access the bulb.
Old May 19, 2012 | 04:42 PM
thor7000's Avatar
thor7000 is infamous around these parts
very easy...just make sure you don't strip the gears on the headlight assembly...hard to explain, you will understand when you check out the manual
Old May 19, 2012 | 09:24 PM
statepkt's Avatar
statepkt is infamous around these parts
instructions on removing the headlight is in your manual. Not too hard at all
Old May 19, 2012 | 10:51 PM
bansasn's Avatar
Thanks guys...you are the best. I am looking at the manual as I typed. So the whole headlight unit comes off? Wow...that's scary. Ok I will work on it. Again...many thanks.
Old May 20, 2012 | 12:25 PM
russnyc's Avatar
russnyc is infamous around these parts
it's a very easy job and kinda fun carrying around the headlight assembly. There are times when I realize they really built these things to be owner friendly.
Old May 20, 2012 | 08:48 PM
bansasn's Avatar
Yes...it was very easy. Gotta hand it to those silly German.
OldBoldPilot
Aug 24, 2015 04:00 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
Jeff1smith
Aug 19, 2015 09:41 PM
Walorus
Aug 18, 2015 01:39 PM
