Gearbox slipping and clunck from transmission
Old Sep 13, 2012 | 05:39 AM
motoadve's Avatar
motoadve is infamous around these parts
Usually when cold slips a bit.
Then gets better.
Mechanic Did a gearbox oil change and mechanic says its even worse, so far he put 6 quarts .
Is there an specific procedure for the gearbox oil change?
How many quarts? 9?
The car has 70,000 miles.
Cayenne S 2004 .
The clunk is from 4 th gear when downshifting to 3rd.
Old Sep 13, 2012 | 11:01 AM
scantu's Avatar
scantu is infamous around these parts
my intent is not to alarm.....
This same thing happened to my 2004. I found that the valvebody was toast. Research shoed that its a common issue on the Cayenne.
Old Sep 13, 2012 | 11:57 AM
motoadve's Avatar
Only 4 quarts fit and the gears are slipping.
It needs more oil but doesnt fit.
How do I make it fit?
Old Sep 14, 2012 | 07:30 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Does it throw a code?
Old Sep 14, 2012 | 01:41 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Is the gearbox at the correct temperature? Is it being filled while the engine is running? Both are a requirement to change the fluid.
Old Dec 10, 2012 | 12:08 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
did the OP ever find the solution to this? I have the same thing happening in my 08 V6 and i doubt the transmission would be toast since it only has 55,000kms on it.
ECS Tuning - BMW
Sep 23, 2015 02:00 PM
nal991
Sep 17, 2015 06:51 AM
ECS Tuning - BMW
Sep 16, 2015 03:02 PM
Twinturbofan
Sep 11, 2015 04:14 PM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
