Porsche Cayenne steering angle sensor problems
Old Oct 19, 2012 | 11:46 PM
gbratk's Avatar
gbratk is infamous around these parts
HI,
I read all treads and I didn't find the right answer for me. So here is my problem.
I have Cayenne S 2004, with steering angle sensor problems. So PSM is not working now.
I read the faults and the only one is:
0778 Steering angle sensor No signal/Comunication Present.
I make test with diagnostic, and there is no CAN communication with that sensor.
So I bay new sensor, change it and no difference. The actual value is always 0 degrees. I also check all wires from PSM unit to steering column, and gateway, and is all fine.
Can please someone help me, coz I don't know what to do to repair this problem.
Could be the problem in steering column electric unit?
I know, that sensor has to be calibrated, but fist the system has to communicate with it and give same values, than has to be calibrated.
Is that right?
Please for some help.
Thank you
Gasper
Old Oct 21, 2012 | 11:16 AM
gbratk's Avatar
really no one has that kind of problem?
Or is maybe someone who changed steering angle sensor?
Old Dec 30, 2019 | 08:55 PM
webzzter's Avatar
webzzter is infamous around these parts
eeprom is 95160, i know only fileservice for fix steering angle
Old Jun 5, 2021 | 02:25 PM
vasilli's Avatar
vasilli is infamous around these parts
I have the same error code. 0778. Just got the car, so don't know the solution. Reading forums. Will be figuring it out.
vasilli@hotmail.com if you wanna talk
Old Oct 31, 2024 | 02:26 AM
Derek Edgar's Avatar
Derek Edgar
I have same error code and car is not engaging to any gears. Did you fix your issue?
armeec_7755
Cayenne 955/957
Feb 2, 2019 10:41 AM
Wealth Manager
Mar 28, 2015 08:40 AM
Fugazi
May 2, 2012 11:34 PM
DMaffo
Mar 25, 2008 07:01 PM
ColorChange
Jul 29, 2005 08:44 PM
