Steering adjustment on my 2004 S
Old May 26, 2013 | 06:53 PM
RIckyuk's Avatar
RIckyuk is infamous around these parts
The electronic steering adjustment has failed on cayanne s. I guess it can be a relay, fuse, motor or switch. Any ideas wher the fuse is located before I start removing the column shrouds.
Also the switch on the drive side door for the rear hatch also has failed although the switch next to it that opens the fuel door is operational. Again any help guys?
Thx
Old May 26, 2013 | 07:31 PM
Dennis C's Avatar
There is a fuse for Servotronic. I don't recall the number, but it should be in the manual.
What issues are you having with the switch? It doesn't actually open the hatch in my car, it just unlocks it and allows you to open the hatch from outside.
Old May 26, 2013 | 08:45 PM
RIckyuk's Avatar
The hatch switch does not release the hatch. I cannot here a solenoid operate around the hatch so I think there is no power to the hatch.
The steering adjuster is my main concern. I do not want to start throwing parts at the problem until I have a better idea of the failure.
Old Jun 1, 2013 | 08:52 PM
RIckyuk's Avatar
Has anyone had to replace the switch on the steering column. I have found one on e bay for $50. Got a feeling that this is the problem. Ideas please?
PV=nRT.
Sep 9, 2022 06:06 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
