Cayenne Turbo Boost Question
Hi All
My 07 Cayenne Turbo at full acceleration only boost to 0.6 Bar at full throttle and slowing going down to .4 bar.
by looking at videos online apparently they all do it.
Is there a way to over ride this so at full acceleration it boosts at .8 bar?
Pretty sure around .6 bar is normal for stock. Not 100% though - I could be wrong since I had an ECU tune within the first week.
here is what I found from another site:
Stock boost pressure for the 450HP Cayenne Turbo should be max 0,6 bar which reduces slightly to about 0,5 bar at higher rpm.
The 500 HP E81 Powerkit should have max 0,8 bar reducing to 0,65-0,7 at higher rpm. (Not verified, but a reasonable assumption based on different sources, feel free to correct this one).
The 521HP Turbo S should have max 0,9 bar reducing to 0,75-0,8 at higher rpm. (Not verified, but a reasonable assumption based on different sources, feel free to correct this one).
thanks for the reply
I have changed the DV to the Forge motorsport one 008 premium ones. as for ECU I do have one in there it is a plug in and play ecu.
the DV helped a lot smoother coming on boost but its just this boost problem im having that at full throttle needle doesn't seem to stay on .8bar as the gauge reads
the cayenne turbo is a 4.8L 957 not the 450hp.
how long was the DV installed? when was it last serviced? what kind of ECU upgrade do you have? one way to solve your issue is to return them back to stock one by one to see which one is at fault.
This sounds a little strange. I would think that anyone who spent a decent amount on money on an ECU tune, would know which performance company tune they went with. Are you positive you have an ECU tune (which is software that is loaded to alter the stock ECU programming)? In the event that you wrote a blank check for several mods at a shop, I would call the shop for clarification on the ECU tune.
I bought the car with the ecu in it. I can see the module but doesn't say the name or any sticker on it. I have unplugged it and it makes a big difference.
but I just found out by playing with the car on the freeway, with PMS off it is like its on steroids and it boosts to the full amount. only on normal drive it doesnt
i have noticed that my boost level doesnt go to 0.8 bar unless if i slowly accelerate the car, otherwise if i floor it at once it will boost anywhere starting from 0.4 bar but no way up to 0.8 bar
turn PSM off and floor it. see how you go
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
