Door lights
Old Dec 18, 2013 | 09:39 AM
cyborg's Avatar
cyborg is infamous around these parts
Door lights
Hi all,
Just installed interior LED set on 957 from sunset but the drivers door lights,puddle & red stopped working. All other lights are fine and switch on / off as normal.
Checked fuse it's ok also no loose connection and once or twice the lights did flicker on for a second, could it be the micro switch which is fitted behind the door handle or the control unit?
Car does not have comfort option, request for advise on what to check.
Old Dec 18, 2013 | 10:03 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
Did you replace both the red lights and the puddle lights with LEDs? I think I've heard that you can do one or the other, but if you do both, they don't work.
Old Dec 18, 2013 | 10:27 AM
cyborg's Avatar
You are correct but I replaced only puddle lights, red are standard...
COBB Tuning
Jan 1, 2025 09:02 AM
twnj
Apr 29, 2016 05:18 AM
J9277655
Dec 28, 2015 11:01 PM
Michael_s
Sep 11, 2015 08:03 PM
GSR Autosport
Aug 26, 2015 05:20 PM
