Glove box light
Old Jan 12, 2014 | 09:33 PM
charlielmarsh's Avatar
charlielmarsh is infamous around these parts
Glove box light
Changed my interior light to leds. They look awesome, but the last light I changed was the glove box light. Switched the bulb and it didn't work so I removed the bulb and switched the polarity, still didn't work. Try the incandescent bulb and that won't work. Everything else in the cayenne works so I haven't check to see if it's a fuse. Any ideas?
Old Jan 13, 2014 | 07:27 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Did it work before. If so why change it? My glove box is open maybe once a month and I couldn't tell if it works or not.
Changing bulb types in these cars frequently causes some sort of problem somewhere.
Old Jan 14, 2014 | 08:56 PM
richie996's Avatar
richie996 is infamous around these partsrichie996 is infamous around these parts
Make sure all of your LED's turn off properly as well. I had a problem when I changed all interior lights on my 09 GTS to LED. The puddle lights under the rear doors would NOT turn off leading to a drained battery every couple of days. Had to sacrifice and install regular bulbs in those locations so they turned off properly.
All other bulbs I installed (suncoast kit, ~14 bulbs) worked perfectly..
Old Jan 14, 2014 | 08:57 PM
Originally Posted by richie996
Make sure all of your LED's turn off properly as well. I had a problem when I changed all interior lights on my 09 GTS to LED. The puddle lights under the rear doors would NOT turn off leading to a drained battery every couple of days. Had to sacrifice and install regular bulbs in those locations so they turned off properly. All other bulbs I installed (suncoast kit, ~14 bulbs) worked perfectly..
All the other bulbs seem to be functioning perfectly. Will have to do some more trouble shooting.
RallyBird
Oct 7, 2015 01:20 PM
GSR Autosport
Aug 26, 2015 05:20 PM
