air suspension faulty - workshop
Old Feb 8, 2014 | 04:17 PM
RTR's Avatar
RTR
RTR is infamous around these parts
Cool air suspension faulty - workshop
I'm getting this warning but air suspension works just fine. Understand previous two owners had same problems (so why not fixed, right?). Any recommendations. I have to have some servicing done to I will have checked. Could be a faulty sensor?
Thanks,
RTR
Old Feb 8, 2014 | 05:39 PM
Dennis C's Avatar
Your problem is most likely caused by an air compressor pump that needs to be rebuilt. There is a rebuild kit that is available for less than $300 and the rebuild is a relatively simple DIY. This is a common issue. As the pump wears out, it's unable to raise the suspension within a predetermined timeframe, and that triggers the warning. Rebuilding the pump will make it work properly.
It certainly could be a sensor or something else, but probably not.
Old Apr 7, 2014 | 10:08 PM
LiketheMonth's Avatar
LiketheMonth is infamous around these parts
I found a rebuild kit on ebay. $30. Then found this video
Took me an hour to do (with lift)
Good luck!
Jul 29, 2019 11:13 AM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
