Irritating Amp/Speaker Buzzing Sound?
Old Mar 13, 2014 | 09:14 PM
purerx7's Avatar
purerx7 is infamous around these parts
Car is a 2009 Cayenne and it seems one issue after another rises, this one being more irritating than anything else. It is caused from one of two things, if I shut the rear passenger side door a LOUD buzzing sound comes from the speaker. Then if I shut the same door hard again the buzzing sound goes away. Or if I go over a pothole or big bump the buzzing sound will start again, it goes away when I slam the rear passenger side door.
I have done a bit of research but haven't found anything conclusive. Seems like it has to be related with the amp? Although from what I read it is a pain in the *** to get access to the amp? Anyone have any ideas or experience a similar issue? If it is the amp, what is the process to have it fixed or perhaps it is a loose connector.
Thanks!
Old Apr 17, 2014 | 06:50 PM
purerx7's Avatar
Anyone? The sound is driving me insane!
Old Apr 18, 2014 | 03:41 AM
gh0stman's Avatar
gh0stman is infamous around these parts
Have you looked at the actual wiring in the door? You could have a loose or worn wire that might be causing your problem.
Old Apr 26, 2014 | 08:13 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
This. It sounds as if you have a bad ground at that speaker, on in its wiring. Take it to your audio dude - or another professional.
Old Apr 26, 2014 | 09:25 PM
purerx7's Avatar
Then wouldn't the sound come out of the speaker in that door. IE if I shut the right back door then the irritating sound is always in the front driver side door never in the right back door. I can shut the other doors without the noise coming on in the front driver side door.
shiftmechanism
Nov 23, 2016 09:02 PM
pwdrhound
Sep 13, 2016 10:44 AM
Feelgood MD
Mar 24, 2016 09:35 AM
cm09578
Sep 10, 2015 05:26 AM
al3656
Sep 7, 2015 06:35 PM
