957 CTT w/ upgraded brakes?
Old Mar 26, 2014 | 04:33 PM
DirtyVegas's Avatar
DirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud of
I am being told by dealer and by an indi shop that I have an upgraded set of brakes on my 09 CTT. They told me that this is a factory brake option on my CTT that is standard on CTTS.
I don't have access to all my new car docs at this time... can someone please let me know if there was a brake option for 09 CTT? Because the brake job quotes that I am getting are border line ridiculous and I just wanted to be sure that I'm not being told stories.
Also, are there better places to buy pads and rotors for our CTT beasts? I know Renaissance.Man said something about buying Brembo rotors on ebay. Is this still an option, even for upgraded brakes?
Old Mar 26, 2014 | 04:51 PM
kevblah's Avatar
kevblah is infamous around these parts
post a picture of your calipers? better yet, PM me your VIN. i'll tell you if it came with a brake package.
Old Mar 26, 2014 | 07:13 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
DV,
Pm me your vin and I'll check out your brake install from factory.
Old Mar 26, 2014 | 07:22 PM
DirtyVegas's Avatar
Here is a picture of my front rotor. I am being told that these are upgraded brakes with a two-piece rotor for which there are no aftermarket replacements. Is this true?
VIN: WP1AC29P69LA83354
ID:	351614   Click image for larger version
Old Mar 26, 2014 | 07:23 PM
kevblah's Avatar
i dont see anything on your build sheet that indicates upgraded brakes
maybe it was done aftermarket?
Old Mar 26, 2014 | 07:29 PM
DirtyVegas's Avatar
I had the car since new and no aftermarket work was done on it. I'm told that the hat (?) screwed onto the rotor (in the pic) is what makes this rotor 'different' than others. These also look somewhat like 380mm CTTS rotors.
Old Mar 26, 2014 | 08:10 PM
Vig03's Avatar
Vig03 is infamous around these parts
Hey DirtyVegas,
Those are two piece rotors as opposed to standard single piece. My 955 CTTS also has two piece 380mm rotors and they are ridiculously expensive when compared to the one piece option. I'm not very familiar with the 957 so I can't say if it was an option. This is really interesting since you've owned it since new. I wonder if the 957 came with an e81 package as offered on the 955s? But, then again, it looks like people have searched your VIN...confusing.
Old Mar 26, 2014 | 08:11 PM
Bigbuzuki's Avatar
VIN WP1AC29P69LA83354
Front rotor left part # 95535140161
Front rotor right part # 95535140261
Rear rotors left and right part # 95535240300
Your dealer is correct, they are the Turbo S variety.
Old Mar 26, 2014 | 08:13 PM
aspenone's Avatar
aspenone is infamous around these partsaspenone is infamous around these parts
Those are the same rotors I have on my CTTS and they are the upgraded brakes...the price for them is crazy check out suncoast porsche they sell them at what Ive been told is wholesale
Old Mar 26, 2014 | 08:24 PM
DirtyVegas's Avatar
Ok... so the indi shop wants $2,700 for parts (pads and rotors) and labor to do my front brakes.
Old Mar 26, 2014 | 08:26 PM
kevblah's Avatar
all this talk has my wondering, what kind of brakes do i have on my 08 CTT?
and wouldnt an upgraded brake package show on the build sheet???
edit: oh i see how mine are different now
Old Mar 26, 2014 | 08:28 PM
aspenone's Avatar
sounds kind of high given that I priced out the front rotors with pads and sensors and came out to $1659 for parts. so say if you rounded it off say 1700 for parts, they are basically charging you $1000 for labor unless they are paying full price for the parts which I beleive jumps it up to over 2k in parts
Old Mar 26, 2014 | 08:29 PM
aspenone's Avatar
Kevblah those are the smaller brakes your not spending a lot on brakes
Old Mar 26, 2014 | 08:31 PM
DirtyVegas's Avatar
Suncoast has the rotors for $1357, pads for $257, and sensors for $44. Is there anything else needed in parts?
How long should the labor be for something like this?
Old Mar 26, 2014 | 08:41 PM
aspenone's Avatar
not sure what they charge for labor near you but I would think they would quote like 2 hours labor...as far as other parts maybe the new bolts I beleive there listed on the site also those are suggested. Oh and change your brake fluid as well its worth it
