957 Cayenne ATF recomendation
Old Jun 14, 2015 | 03:40 PM
  #31
VTGT's Avatar
VTGT is infamous around these parts
I used oem fluid, filter etc. I had no shaving ar 105k and trans shifts as new. I wouldn't cheap on fluid if you can avoid it.
Old Jul 23, 2015 | 07:24 PM
  #32
Blubayou's Avatar
Blubayou is infamous around these parts
Trans fluid type
I will be using Aisin T-IV to replenish after an OEM filter change this weekend.
Old Jul 25, 2015 | 05:50 PM
  #33
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
I use Beck & Arnley T-IV
Old Aug 10, 2015 | 01:59 AM
  #34
waltertm's Avatar
waltertm is infamous around these parts
The oem atf is a good fluid but if you want a good alternative, go with Redline.
Old Feb 4, 2018 | 08:17 PM
  #35
Defran1992's Avatar
Defran1992 is infamous around these parts
Originally Posted by TurboTodd
Okay so I did the trans service last weekend. Easy peasy, well within the capabilities of an average person. I obtained a nice kit from ECS tuning with the Redline D4 and used their excellent DIY.
Some observations,
I made sure my Durametric measured trans ATF temp first, and it did.
I also made sure I could remove the fill, drain and pan bolts before I ordered the kit.
Take your time with the pan bolts. Some of the bolt holes are open all the way though. That lets water, salt and everything else to collect in there and corrode the bolts. I used PB blaster and time to remove them.
I would highly recommend new pan bolts.
I also highly recommend the Motive fluid transfer pump. I dont think you could get the fluid in fast enough before the trans hits 40c with a hand pump.
I think the Porsche 160k mile change is a joke. The fluid removed was very dirty. I did not do an oil analysis and that well may have proved the oil had life left in it. For me it it looks like a dog and smells like a dog .. its a dog.
Immediate results, the shift from 1st to 2nd comes noticeably sooner. All the shifts are more positive. Of course this is with only a couple of days on it. We will see long term.
Sorry to bring up the old thread, but do you remember if you went with the Genuine Porsche brand kit or the other kit that's assembled by ECS tuning?
Velgen
Cayenne
Nov 30, 2015 04:05 PM
jdbaker
Sep 19, 2015 10:34 AM
Brooklyn boosting
Sep 16, 2015 10:05 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
arhim22
Sep 7, 2015 08:49 PM
