Oil Change ??
Old May 10, 2014 | 04:17 PM
kmcc927's Avatar
kmcc927 is infamous around these parts
Oil Change ??
Does the drain plug have a O-ring? Had oil change done and it is leaking badly at the drain plug. 08 CS. Thanks
Old May 10, 2014 | 04:48 PM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
Yes. It has a metal crush washer. The washer is likely in the drained oil. They should be changed every oil change. I bought about 10 from suncoast so I would always have one.
Old May 10, 2014 | 04:52 PM
kmcc927's Avatar
Thanks, That answers my question. Looks like I need to find one...they lost it...
Old May 10, 2014 | 04:55 PM
Dennis C's Avatar
Sometimes the drain plug gets cracked during tightening, causing a leak. If it's not the washer, then you might need a new plug.
Old May 10, 2014 | 05:01 PM
kmcc927's Avatar
Do you remember the size? Thanks
Old May 10, 2014 | 06:12 PM
mtnrat's Avatar
The washer is about 1.25mm thick. Outside diameter of 24mm, inside diameter of 18mm. My battery is dead for my digital caliper so best I could do. I would also say it is made of aluminium.
Old May 10, 2014 | 06:41 PM
kmcc927's Avatar
Thank you! Exactly what I need.
Old May 11, 2014 | 01:37 AM
ciaka's Avatar
Aren't there 2 drain plugs for the C?
I do change them almost every change....if I do not, I flip it so that the metal surface works its way into the metal of the pan better...but then make sure to replace next change.
Got about a dozen off ebay and have on hand to do changes with. Cheap item too, so knock yourself out.
Old May 11, 2014 | 08:29 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I would return to the shop where you had the work done and have them check and correct the problem immediately. That's what you paid for.
mtnrat's Avatar
Yep, there are two.
Old May 12, 2014 | 08:51 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
There's only one drain plug on the 957. Two on the 955 V8s.
Old May 12, 2014 | 12:51 PM
gh0stman's Avatar
gh0stman is infamous around these parts
Just be happy that the mechanic hadnt got to the point of using a flat head and hammer to put those things on, after stripping out the center of the plug.
Old May 28, 2014 | 07:25 PM
thor7000's Avatar
thor7000 is infamous around these parts
where is the second drain plug??? I just changed my oil tonight and only found the one!! I added 9L of mobil 1 0w40 and it's reading a little high on the dipstick.....just over the max line, should I be concerned or leave it??
Old May 28, 2014 | 07:38 PM
09RedGTS's Avatar
09RedGTS is infamous around these parts
Nobody answering, so I'll give my two cents worth. It sounds like you got it all out if you needed to add near 9 qts. It is not good to be over the high Mark on the dipstick due to possibility of the crankshaft making foam in the crankcase because of high oil level. I would test it by driving it a bit and checking after it settles a few minutes, and repeat several times until oil is fully hot. If you see no evidence of foaming at any time, it is probably going to be fine. Otherwise you you could try to drain a pint or so, which is a pain but might be what you need to do.
Old May 28, 2014 | 07:40 PM
thor7000's Avatar
Thanks for the reply....I will definitely keep an eye on it. Do you know where to 2nd drain plug is??
