idler pulley replacement
Old Jun 18, 2014 | 10:06 AM
cmoore1's Avatar
cmoore1 is infamous around these parts
I have a 2006 CS with 68K miles. My mechanic says the left idler pulley needs replacement. Should I replace both idler pulleys, the tension pulley and the serpentine belt at the same time? What about the tensioner shock?
Old Jun 18, 2014 | 05:20 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Well, I would ask the mechanic who has already inspected your equipment. The belt may, or may not, need replacement now but it will so while you're in there - I would. As far as other pulleys, I would only do them all if they showed sign of need.
Old Jun 18, 2014 | 07:27 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
Change all pulleys, belt, and belt tensioner whilst his in there.
Old Jun 23, 2014 | 07:54 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Originally Posted by bigbuzuki
change all pulleys, belt, and belt tensioner whilst his in there.
+1...
r_matt_6
Oct 8, 2015 06:07 PM
RallyBird
Oct 7, 2015 01:20 PM
turbotuner20v
Sep 11, 2015 12:02 PM
spreeon
Aug 27, 2015 08:14 PM
LiquidElephant
Aug 27, 2015 06:17 PM
