Another Diverter Valve Option...
Old Sep 23, 2005 | 11:56 AM
Wilson@Champion's Avatar
Wilson@Champion is a jewel in the roughWilson@Champion is a jewel in the roughWilson@Champion is a jewel in the roughWilson@Champion is a jewel in the rough
Champion Motorsport and Forge Motorsport have worked together to come up with a diverter valve that will better fit the cramped engine compartment of your 996 twin turbo and Cayenne twin turbo.
This new valve does not require maintenance (re-greasing) like the aluminum piston style valves. The valve uses a design similar to Forge's DVR Fast Response valves which utilizes a diaphram. This new valve, however, does not use a rubber diaphram. It utilizes a composite material which holds up better in higher boost situations. The vacuum port is located on the side of the valve to help save space and it is also adjustable to better help ease of installation.
The valves are available for purchase either through Champion Motorsport or any of Champion Motorsport's Dealers.
Price: $150.00 US
***** Click here for a quick video of the adjustable valve port *****
Old Oct 22, 2005 | 02:27 PM
Updated with pricing.
Old Oct 23, 2005 | 07:47 AM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
You can also buy the new Hyperboost HX Compact Diverter valve which will fit under the hood of the Cayenne TT.....I just had these installed and while i cant really hear the difference yet i can see it in the boost gauge with better turbo response and a more fluid needle response . . . . .
Hyperboost HX Compact D Valves
They show all the hyperboost products scroll down to the info about the HX Compact!!!
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
