Cayenne Battery Sleep Life?
Old Dec 6, 2014 | 06:53 PM
dancingbears's Avatar
dancingbears is infamous around these parts
My ‘09 CTTS doesn’t like being left “sleeping” in the garage very long before its battery doesn’t have enough juice to start. 25-days or more and it’s questionable whether it needs a jump.
I bought the car used three years ago so I’m not sure if the battery is original. However, I’m curious what others experience before this happens. Is three to four weeks about the norm? I have three Porsche's, so I know they suck power like crazy just sitting in the garage. Do I need a new battery?
Old Dec 7, 2014 | 07:31 PM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
I really don't know the life of the battery when it just sits. If I know I am not going to drive for an extended period I disconnect the negative terminal. I do this especially when on vacation, as there is nothing worse than coming back from a tropical vacation and trying to start the car at -20 and the battery has drained and need a jump in one of those huge airport parking lots.
Old Dec 8, 2014 | 10:27 AM
Waitin4Dv's Avatar
Waitin4Dv is infamous around these parts
Mine only lasted about week and a half and I had to jump
Old Dec 14, 2014 | 07:11 AM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
You need a "battery tender" they are 25 bucks.
Hook it up when your not driving if its going to sit that long. They say all the control units and stuff have a non volatile memory but strange stuff seems to happen. Kinda like when you run your phone all the way down to 1 or 2 % over and over.
Old Dec 15, 2014 | 08:05 AM
09RedGTS's Avatar
09RedGTS is infamous around these parts
Batteries will self discharge even if not connected and it is not good for them. A battery tender is the solution. There are plug in models and solar powered ones. There is a nice Porsche approved one you can get without the Porsche label for a reasonable price. I think it's the CTEK for $50something. They say it can even help bring back a sulphated battery. Check it out...
Old Dec 15, 2014 | 07:43 PM
Waitin4Dv's Avatar
I'll check it out
Old Dec 21, 2014 | 09:31 AM
richie996's Avatar
richie996 is infamous around these partsrichie996 is infamous around these parts
All newer cars have this flaw, with the amount of electronics running at all times the batteries will slowly drain overtime. Add some cold to the mixture and they drain even faster.
I use a Schumacher 1.5a trickle charger/battery maintainer ($20 from amazon) and it does the trick for my cars.
Model: Schumacher SEM-1562A-CA
Ofcourse, if your battery is still the original factory one and it's past 4 years, your battery may be going as well.
On my 1985 Bitter SC, I haven't replaced the battery in over 15 years using a maintainer.
Old Dec 25, 2014 | 11:01 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
No issues here on any current or past Porsches. You should be able to leave it alone for months without issue. If you've had it for 3 years and don't know how old the battery is - you probably need a new battery. It's pretty simple to have it tested and see if it's strong.
adnanm3
Nov 22, 2023 02:43 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
oo7
Sep 10, 2015 08:08 AM
