MAF Sensors - 2008 Cayenne V6
Old Mar 13, 2015 | 06:59 AM
grdlaw's Avatar
grdlaw is infamous around these parts
I got a CEL and ran a diagnostic on the Durametric and got a P1090 error code. From what I've read it is most likely a problem with the Mass Air Flow (MAF) Sensor.
My question is, how many Mass Air Flow Sensors does a 2008 Porsche Cayenne V6 have? A DIY instruction on another site said it has 2 MAFs, but I don't know if it was specific as to a V6 or V8 model.
Old Mar 15, 2015 | 04:06 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Should only have one. The Turbos have 2
Old Mar 15, 2015 | 07:40 PM
grdlaw's Avatar
Thanks! I ordered 2 just in case.
Old Mar 17, 2015 | 03:02 PM
grdlaw's Avatar
MAF Update
My 2008 Porsche Cayenne V6 has 1 MAF sensor. Earlier this morning before the new MAF sensor came in, my CEL came on again and I ran the Durametric and came up with the P1090 Fault and P1109 Fault. From what I read, these faults usually point to a bad MAF. I reset the faults and installed the new MAF. The MAF is a Bosch aftermarket part, which coincidentally is the same as the one I replaced. Hopefully this takes care of the faults.
On Thursday, I am having the Fabspeed Secondary Catbypass pipes installed while keeping the oem exhaust and tips. Eventually, I will upgrade to the Fabspeed Maxflo mufflers and pipes. I am also going to have the EPS Rear Driveshaft Center Support Upgrade Kit installed. Having recently installed new spark plugs and coils at 99,000 miles, the only thing I am waiting for is the transmission kit to be delivered so that I can have the transmission oil, filter and gaskets changed and the PIG will be like new!
Old Mar 17, 2015 | 09:28 PM
09RedGTS's Avatar
09RedGTS is infamous around these parts
I was told my GTS had 2 AMFS. I never tried to clean them. Just kept resetting the trouble codes and the check engine light for the Durametric AMFS trouble code would stay off for 2-10 days typically. Sometimes it would even go off by itself. It poured like a cat, so I knew it was a nuisance trouble code. Two different techs told me the AMFS wires needed cleaning with CRC spray, but I never got around to that b4 trading recently for myth Cayman S.
Old Mar 24, 2015 | 07:20 AM
BOOSTTT's Avatar
My Durametric scan said my LEFT MAF was out, so I replaced it, but still had the same problems, then put the old left one on the Rt. and now it all works? Does Duramertric call the driver's side Rt.? strange. Anyway, it worked. cleaning only bought me about 2 wks.
Old Mar 24, 2015 | 08:09 AM
09RedGTS's Avatar
Interesting! Very clever move on your part.
I think mine said something like 'value beyond limit'. But I traded for a 2014 Cayman S. Whatever it was on my Cayenne GTS, it never affected the way the engine ran. It always purred and rumbled smoothly, like a large cat.
NTIMD8
Sep 1, 2015 09:58 AM
ritchrwi
Aug 29, 2015 08:27 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
