Durametric Fault Codes P1109 & P1090
Old Mar 24, 2015 | 03:04 PM
grdlaw's Avatar
grdlaw is infamous around these parts
Background: Installed Fabspeed Secondary Catbypass Pipes, new Mass Air Flow Sensor and aFe air filter (non-oil) in the last week. CEL light came on and I ran the Durametric resulting in P1109 and P1090 fault codes.
P1109 - Evaporative emission system leak detected (large leak) - Upper limit value exceeded, test conditions are not completed, fault is currently active and causing a DTC light
(From prior threads, this fault can be 1. Heavily soiled throttle; 2. Throttle adjusting unit faulty; or 3. MAF sensor faulty)
P1090 - Evaporative emission system leak detected (small leak) - Upper limit value exceeded, test conditions are not completed, fault is currently active and is not causing a DTC light
I'm assuming that since I just replaced the MAF, that is not the issue. Thus, I'm assuming that the problem is with the throttle. I just cleaned the throttle body assembly with cleaner and a cloth. Hopefully this takes care of the problem and the CEL doesn't return.
What else could be the problem if the same codes return?
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
1gr8e39
Oct 1, 2015 04:07 PM
Nuke
Sep 8, 2015 09:09 AM
arhim22
Sep 7, 2015 08:49 PM
