Help with coolant pipes
Old May 25, 2015 | 06:43 PM
Waitin4Dv's Avatar
Waitin4Dv is infamous around these parts
Hi doing my coolant pipes and trying to figure out what this single o ring is for? If it's supposed to go in before I put the coupler on the larger single pipe woundnt I need one for each side? It says only one for quantity so I must be mistaken where it goes. My picture is with couple installed with the two factory o rings attached. Just wondering if I'm supposed to put the black one in first then push coupler on but then I should of received one for the other end if I'm right any help this is the ecs kit.
Old May 26, 2015 | 03:11 AM
gh0stman's Avatar
gh0stman is infamous around these parts
It has grooves in it right? I believe the orings go into the grooves if we are talking about the same part.
Old May 26, 2015 | 07:57 AM
Waitin4Dv's Avatar
Yeah that piece had grooves and there were o rings on it. I ended up putting it in the thermostat housing side first before I stuck the big pipe in. It felt loose if I didn't put the o ring in first
Old May 27, 2015 | 04:31 AM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
Old May 27, 2015 | 07:39 AM
Waitin4Dv's Avatar
Yeah I'm using there instructions but says nothing about that single o ring and it came with two thermostat housing gaskets.
Saint Ari
Jan 17, 2022 09:22 PM
Rguy
Apr 12, 2020 11:11 PM
Yogi911
Sep 9, 2015 08:20 PM
