05 CTT Air strut removal question
Old Feb 21, 2016 | 10:33 AM
ciaka's Avatar
If I want to remove the front air strut, do I need to get any kits that replace any connector parts on the strut air lines? Was looking at some videos and it appeared the airline to the strut has some plastic connectors, and wan to make sure I don't run into problems afterwards.
So basically info on any replaceable hardware when removing the shock will be greatly appreciated.
Thank you.
Old Feb 24, 2016 | 02:06 AM
ciaka's Avatar
Thank you. After looking closer I see three different parts and I would like to find out if any of them have to be replaced if I remove the connector from the struts. The three parts are:
95535872002 - pressure valve for air strut
95535872200 - sealing ring for the valve
95535854100 - push on connector air tube
So if anyone can advise if these can be reused when servicing strut, that would be great. Thank you in advance.
Here is diagram link
PelicanParts.com
Feb 10, 2016 11:54 AM
TURBO ELECTRO
Feb 1, 2016 09:45 PM
HotRodGuy
Jan 30, 2016 04:18 PM
hollynitro
Jan 29, 2016 11:29 AM
P997S
Jan 28, 2016 11:52 PM
