LED Reverse lights????? Help
Old Jun 26, 2016 | 09:56 AM
alpesh26's Avatar
alpesh26 is infamous around these parts
Originally Posted by Porscheman33
My friend has a 2013 also and he had to also code the error code off. I got lucky with the 14 LOL. But I love the way they look so much. Ill try JDM toy I guess.
Yeah I really miss my A4, I moved countries so I had to let it go. When i move back, i'll probably get another A4...maybe an S4. You could do quite a few things with VCDS on the later ones, you can't do many mods with Durametric on the Cayenne!
Old Jun 26, 2016 | 08:12 PM
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
Oh man right? Thing is crazy. I love my A4 so much. You should see the list of VCDS mods I have on it. It goes on and on. I haven't found anything fun to do with the Cayenne involving the Durametric.
I was going to get an S4, but coming from an M5 I felt I didn't need the power again. The A4 was the perfect choice. I never regret it. Maybe down the line I'll buy another car that has a **** load of power like the M5.
Old Jun 27, 2016 | 06:20 AM
alpesh26's Avatar
Needle sweep/staging was my favorite mod on the A4...very childish haha! Either way, whichever Audi I buy, it will be quattro
Old Jun 29, 2016 | 10:07 AM
Right? The needle sweep Is something I look forward to every time I get in. I love that I can close my sunroof from my house.
Quattro is insane, I don't think I will ever be able to live with out one now. This past winter we had a Road Ban, Meaning the roads where so unsafe to do snow that we weren't allowed to go out. If we did we risk getting arrested. (That never happens, you can drive past cops and they don't care lol) But I went out and I was the only one on the road, deep deep snow and it drove like it was a summer day.
Old Jun 29, 2016 | 10:11 AM
Added some pics
ID:	452326   Click image for larger version
Old Mar 8, 2017 | 12:39 PM
Has anyone found LED lights for this yet? The yellow is starting to drive me insane... I've tried to get bulbs from other cars that use the same bulb code. but one will plug in and work but as soon as I plug both in, none light up.
Old Mar 8, 2017 | 06:15 PM
Anyone?
Old Mar 9, 2017 | 06:17 PM
I'm gonna keep commenting till someone helps
Old Mar 10, 2017 | 03:34 PM
Anyone gonna pull threw?
Old Mar 12, 2017 | 01:17 PM
This gonna be at the top for ever lol
Old Mar 22, 2017 | 02:04 PM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
No one has done led headlights on a 955/957 cayenne from my knowledge.
Old Mar 29, 2017 | 08:50 AM
Not headlights reverse lights...
Old Apr 21, 2017 | 02:53 PM
5hiza's Avatar
5hiza is infamous around these parts
I'll chime in...I used the LED bulbs from ECS tuning (originally used on my 2000 S4) they fit, they light up, but they code out with a warning on the dash. Even after they code out, they still work though, so I'm not sure of your exact problem.
Old Apr 21, 2017 | 05:28 PM
I have the ECS ones on my 03 Vert A4, ( B6) When I put them in my Cayenne it lit up, on one side then when I put the other side in they both went out.
Old Apr 23, 2017 | 12:48 PM
Domino's Avatar
Domino is infamous around these parts
There is one really cheap fix for these crappy cheap LED's. You will need at least some rookie soldering skills, a pair of original (non-LED) bulbs, few meters of wire. Just solder your original bulbs in parallel circuit with your LED's and put them somewhere they cannot set your car on fire. Not recommended to use this fix for constantly-on lights, because your classic bulbs will get really hot over time and that can make some permanent damage to your car. Downsides - you'll have to cut into your lighting wiring. Upsides - you have your LEDs running without errors.
