2010 Cayenne GTS Pros and Cons
Old Oct 12, 2018 | 05:34 PM
fromwrxto330ci's Avatar
fromwrxto330ci is infamous around these parts
Question 2010 Cayenne GTS Pros and Cons
Im looking into getting a 2010 Porsche Cayenne GTS. I searched the forum for possible problems related to the Cayenne. I came across the cooling pipes but later figured out from 2007+ Porsche replaced rubber hoses with aluminum pipes.. My questions are:
What other vehicle/engine problems should I be aware of..?
What should I look for when inspecting the Cayenne..?
Thanks in advance.
Old Oct 16, 2018 | 08:30 AM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
1) drive shaft at 100k miles i think
2) coils can go
3) starter motor seems to have a shelf life shorter than many.
4) i think that version of the head unit has problems installing satellite radio if it was not part of the build - at least my 2010 turbo cab similar head unit did.
mileage related for most of the above.
they are the best Cayenne imo , having owned a Turbo as my first version, i find this one much more fun. not as fast, but the sound alone kills the turbo.
btw - if you can find a full leather interior , i recommend it - looks so much better.
Old Oct 16, 2018 | 08:02 PM
TCZ's Avatar
TCZ
TCZ is infamous around these parts
I have had my 2010 GTS for a year now. Nice vehicle. It has been solid. Issues to date are clogged AC drain that caused wet carpet on passenger side and a slow oil drip from upper oil pan gasket (a drop on the garage floor every couple weeks). It costs a fortune in labor to fix so I am living with it for the time being..... The PCM is quirky (random reboots, etc...). Had the same issue with the PCM in my 07 Carrera S.
*I love the leather/alcantra seats!
Old Oct 19, 2018 | 07:28 AM
Cpa4S's Avatar
TCZ - so you lowered it 25 mil - what bench is that from? 25 mil lower than the bottom entry level or from the stock or from the sport mode ? you have to do an alignment o something as well if you drop it like that?
Old Oct 19, 2018 | 09:27 AM
TCZ's Avatar
TCZ
I had it done at a shop. Pretty sure it should be down 25mm from every level. But to be honest I think it is only super noticeable at Load Level (so looks great when parked). I want to give it another shot because I would like to be lower in the lowest driving mode. May have to do lowering links. Common sense would be that an alignment should be done but I haven't done one yet and tires show no excessive wear.
hk996tt
Mar 17, 2009 10:13 PM
hk996tt
Mar 16, 2009 03:04 PM
Rave TT
Mar 1, 2004 05:37 PM
