Window washer nozzles acting up
Old Feb 21, 2019 | 09:48 AM
ciaka's Avatar
I noticed both my washer nozzles in the CTT are starting to act up. The spray coming out appears to look like it is not spraying evenly. Wonder if they can get clogged up, and what the solution can be. Do they need to be replaced? Has anyone tried to fix successfully? Have not really tried to remove and play with them yet. Hope someone has experience with them here.
The washer nozzle part numbers is: 955 628 077 01
Thank you for any help.
Old Feb 28, 2019 | 06:07 AM
RazMan's Avatar
RazMan is infamous around these parts
Quick and easy fix is to insert a fine needle in the nozzles - it's probably just limescale or crud from the washer fluid.
Old Jul 26, 2019 | 08:01 AM
ciaka's Avatar
That was it. Inserted thin metal needle into the end, wiggled around, problem fixed. Thank you.
Franc01
Apr 9, 2018 11:47 AM
Barth
Jun 2, 2017 01:03 AM
Paul540/m3
Dec 29, 2011 05:57 PM
