Cayenne 955 air suspension problems
Old Jan 2, 2021 | 12:35 PM
123ricci73's Avatar
123ricci73 is infamous around these parts
Hi all, new year’s here and first posting.
red air suspension illuminated. No air in any strut and car sat lower than loading level. Scanned the full system and got one code 0668 Vehicle voltage terminal 30. I replaced the battery then
checked all fuses (rHD side) all ok. Replaced 40amp relay (373)under the dash, removed compressor pump and replaced piston ring, tested with separate battery and worked fine. Reinstalled the unit and fired up the engine, cleared the above fault code and the compressor will not run at all.
Any ideas on my next move please?
Many thanks for your time and Happy new year.
Old Jun 1, 2021 | 01:58 PM
kennywalker75's Avatar
kennywalker75 is infamous around these parts
I just bought a new compressor mines burnt up works perfectly now 06 Cayenne S
Old Aug 15, 2021 | 04:17 PM
Davd944's Avatar
Davd944 is infamous around these parts
Hi,
did you ever resolve this problem. I have identical symptoms.
thanks
Dave
Old Nov 28, 2021 | 09:27 AM
Longbow's Avatar
Longbow is infamous around these parts
Had the same issue with my 957. After changing the compressor piston ring to no effect I bought some find leak spray.
this showed that several air hoses on the valve block were leaking. Couldn't tighten them as the porsche plastic block wasn't man enough. Bought a new compressor with new valve block. Vw tourag as it's same a Porsche but less cost. All new fittings are brass and cured the problem.
Old Sep 8, 2022 | 03:48 PM
samsongee's Avatar
samsongee is infamous around these parts
i have the same problem going on. Wonder if the compressor had a short and replacing would help.
goose_b
New Member Introductions
Oct 26, 2016 11:04 PM
