Broke my virginity
Old Apr 30, 2006 | 07:56 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
Broke my virginity
Drag racing .. it was the first time for me and the funny thing is my best time was on the first run. Here are the results... only performance mods i have done is airfilters and gemballa muffler.
60' 2.336
330 6.484
1/8 9.907
1/4 15.318
MPH 90.95
Not too happy with the results but oh well.. time for a super charger and some mods.
Old Apr 30, 2006 | 09:39 PM
bentley500's Avatar
bentley500 is infamous around these partsbentley500 is infamous around these parts
hey nice man! Which dragstrip did you take it to? Did you run against anything else?
BD
Old May 1, 2006 | 01:09 AM
jamy85's Avatar
Boobie Stars
Ya i ran against a bunch of cars that kicked my *** lol
Old May 1, 2006 | 01:11 AM
TCM's Avatar
TCM
TCM is infamous around these parts
Lmao, great line JAMY. Glad to see you got the truck out to New England Dragway. Hope you at least had some fun. Those numbers are not that terrible considering you are moving 6k lbs of vehicle or so. When did you do this? Friday evening?
Old May 1, 2006 | 01:10 PM
codey's Avatar
codey is infamous around these parts
Did you run with PSM off?
Is 15.3 what a Cayenne S will usually run. I was under the impression they run high 14's from the factory. Maybe I am mistaken.
Old May 1, 2006 | 01:58 PM
MeanMachine's Avatar
Not bad for a Cayenne S
Old May 1, 2006 | 02:03 PM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
Anyone want to plan a group trip up there for the wednesday/ friday night drag races??
Old May 1, 2006 | 02:50 PM
jamy85's Avatar
Boobie Stars
PSM was off. A stock Cayenne S is 15.4 according to some magazines.
Old May 1, 2006 | 02:52 PM
jamy85's Avatar
Boobie Stars
I believe I can get into the high 14's I just need to experiment more into my launch. When I launched the first 2 times my RPM was around 2000
Old May 1, 2006 | 02:57 PM
jamy85's Avatar
Boobie Stars
Im down....
Old May 1, 2006 | 03:38 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
nice time. when you get a little quicker maybe you can start racing hyundai's
Old May 1, 2006 | 03:39 PM
GoldenPEPPA's Avatar
GoldenPEPPA is infamous around these parts
I'm an old timerdrag racer and I can help a bit.
First... you'll knock .2-.3 off your time by switching out your 22" for some small wheels. Try to bolt on some 18" OE alloys with 255/55's on them.
Remember, those 22" wheels and tires weigh near 80 pounds... the 18's are 55lbs... it will help a lot.
Your 285/35-22's also hurt your torque multiplication by their height.
You have NO traction concerns so the small wheels and tires are the hot tip!
Also try to stall the converter as high as it'll go at launch to get you into your torque curve faster. Also remember that stock motors don't make their best power on the top end, so if I were you I'd probably short-shift slightly from 1-2 and 2-3... maybe 6200rpm, this will get you back into the torque band faster than letting it wind up to 6500.
Also add a octane booster, this will allow the ECU to dial in max advance timing.
I see you going 14.99 the way the car sits today
Old May 1, 2006 | 07:58 PM
techm8n's Avatar
techm8n is infamous around these parts
Did you run automatic or shifted manually? What gear did you launch at 1st or 2nd?
60' 2.336
330 6.484
1/8 9.907
1/4 15.318
MPH 90.95
Old May 1, 2006 | 09:10 PM
jamy85's Avatar
Boobie Stars
jamy85's Avatar
Boobie Stars
Thanks.. Ill try that when I go this week!
