Just curious
Old Jul 11, 2006 | 11:32 PM
ehaser1's Avatar
ehaser1 is infamous around these parts
Just curious
Is there anyway to convert a cayenne to a biodiesel capable vehicle? I'm not sure if you can do it with a turbo but how about an S or regular cayenne? I'm not a mechanic so please excuse my ignorance..
Old Jul 13, 2006 | 02:35 PM
hk_usp9f's Avatar
hk_usp9f is infamous around these parts
No way, unless you do an engine/powertrain swap and a massive change to the whole electronics in the vehicle. Might as well throw everything out and use just the shell of the vehicle.
It will likely cost more than the Cayenne itself.
It's just the wrong kind of engine/fuel/ignition system. Think of how it will screw up the PSM.
Gasoline needs to be vaporized in the cylinder to become an air/fuel mixture. Diesel/biodiesel is too thick to be vaporized using the same fuel injection system.
Gasoline needs a spark to be ignited. Diesel relies on a higher compression ratio to compress the air/fuel mixture until it explodes.
Why, why do you ask? Unless this is a mad science project I can't see why the idea even crosses your mind.
Old Jul 13, 2006 | 10:58 PM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
why?
why not hybrid?
Old Jul 14, 2006 | 10:10 AM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
when is hybrid coming out?
i need a hybrid vehicle.
FUTURESTAR
BMW //M
Nov 18, 2015 10:37 PM
drspeed
Oct 3, 2015 12:43 AM
Ekaplan1020
Oct 2, 2015 07:39 AM
marcallan
Sep 26, 2015 09:07 PM
XLR82XS
Sep 26, 2015 01:46 PM
