AC smells, brakes sqeek....????
Old Nov 3, 2006 | 08:13 PM
MRazore's Avatar
MRazore is infamous around these parts
Anyone have this problem, the AC when i first turn it on sometimes will smell like sh*t. What can sove this problem.
Also, my brakes sqeek at low speeds and it is verrrry annoying, what can i do, change pads? bleed??
Old Nov 3, 2006 | 08:22 PM
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
I've had both those problems. The air conditioning is like a random thing that happens every once in a while, and i hate it. My brakes were squeeking and it turned out i needed new rotors it cost like a grand
Old Nov 3, 2006 | 08:29 PM
bentley500's Avatar
bentley500 is infamous around these partsbentley500 is infamous around these parts
i have only 6,800 miles and my brakes are also starting to squeak at low speeds... do i also have to change them? Or can i wait for another 2,000 miles??
Old Nov 3, 2006 | 09:29 PM
kooser's Avatar
kooser is infamous around these parts
I've had one occasion that lasted about 4-5 days where my AC smelled like a rancid baboon's ***. Thought that the auto-wash place used air freshener that they sprayed into the vent, and no they didn't use "rancid baboon *** scent", but I thought maybe since it was moist in there it might have built up some mold or something. It only happened for the first few minutes of turning it on but if I cranked it up, choked down the vomit in my mouth, and opened the windows, it passed after about 3-4 minutes and then everything was fine.
Not sure of the real cause but I don't let them spray anything in the car anymore. The only time that I have smelled that same nasty odor again since this period was just recenlty at the primate house at D.C.'s Zoo.
Old Nov 3, 2006 | 10:46 PM
20C4S's Avatar
it's the mold in the AC ducting. turn ur AC all the way to HOT & max air. let it run for few mins. it'll solve ur problem for a good while.
for brake squeak, it's even more common on the SUV since it's heavy. do u like the ride on the brake? if that's the case then u need to re-surface the rotors. who wash ur car? make sure don't use wheel cleaner or anything with acid. they're bad for the pads. the squeak might be other reason but above are the most common one i see & easy to fix.
Old Nov 4, 2006 | 03:12 AM
MeanMachine's Avatar
The AC is something I dont want to talk about with my Cayenne, It smells like socks 24/7.
Old Nov 4, 2006 | 05:14 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
Semi-metallic squeak is very common. Be careful about riding the brakes- down shift when you can. Like 20 CFS said, blow out the air for a while and it should clear out, otherwise something is in the system.
Old Nov 4, 2006 | 05:33 PM
djantlive's Avatar
change your cabin filter every 10-15k. it could have accumulated junk. also look at the vent at the bottom of the windshield. any leafs and stuff that is clogging up the ventilation intake?
turning off the ac a little before shutting down the car going forward can help to remove moldy smells.
Old Nov 4, 2006 | 09:18 PM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
Originally Posted by 20C4S
it's the mold in the AC ducting. turn ur AC all the way to HOT & max air. let it run for few mins. it'll solve ur problem for a good while...
my friend did it to his and solved problem.
he treated me with lunch...
arling deserves lunch...
Old Nov 4, 2006 | 09:24 PM
20C4S's Avatar
great! it will come back though. but at least it'll be gone for awhile.
Old Nov 4, 2006 | 09:28 PM
kooser's Avatar
Dealer found a dead and decaying mouse in anither dudes Cayenne Ventilation. I bet that smelled hainus!
Old Nov 5, 2006 | 02:58 PM
MRazore's Avatar
thanks for the suggestions i will try them out, hope they dont find a mouse......
ModBargains
Oct 13, 2015 03:40 PM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
